Results 1 to 24 of 24
Thread: Boost/load targets on new 3port EBCS and turbo
    Jr Member DLYDRVN's Avatar
    May 2013
    Toronto/Kitchener
    2009 Speed3, Yoz. Mazda2
    110 Post(s)
    Default Boost/load targets on new 3port EBCS and turbo
    Welp, the 'Hybrid' k04 I got back from Cherry Turbos is installed, car is now running and idling well and Cobb EBCS in 3port all seem to be working great. Slow as fack tho on super conservative tune. 14psi FTW.... I'm approaching about 50% of my original WGDC but still can't make boost/load targets.
    I'm making around 1.6 load in an RPM range i've set 2.01. Boost holds steady at 14.1, well below 19psi target....
    I was told a good general rule for 3port was to 1/2 WGDC, and for the larger compressor in this new k04 to reduce WGDC a bit as well. So I started around 1/4 of my original WGDC and worked up a bit last night and today, but approaching the 50% mark and wondering how safe it is to push harder.
    Shouldn't be any other tables I need to adjust for these two mods? (EBCS and larger compressor
    Might be time for me to pro tune. I'm loving learning from great people and reading and tweaking, but my head isn't good with the actual practice of tuning!
    Performance COBB AP v3 (345whp/360wtq) - CS Puppy Power Turbo - HTP 3" Widepath - Turbosmart BPV - CS TMIC - Cobb 3-Port - Teflon TIG - CS Catch Can - Autotech Internals - UR 3" Turboback Exhaust - ACT 6-Puck Ceramic Clutch Kit - Filled TMM - CPe RMM - JBR Short shifter - CS Short Shift Plate - Shifter Bushings - CS Front Big Brake Callipers - StopTech Sport 309 Pads - CS FSB - CS RSB - Bilstein B14 PSS Coilovers - CS Mid-Brace - Defi Gauges - CS Steering Wheel - FAST Underground 18x8 - BFG gForce Sport comp2 235/45r18
    Sound & Appearance Kenwood eXcelon DNX893s - JL C3-570 - JL 10W6v2 sub - JL XD400/4 - JL XD600/1 - Kinetik 600 Power Cell - 2AWG Big 3 - Redline Boots - CS LED Fogs - CS Lic. Plate Kit
    Moderator loki's Avatar
    880 Post(s)
    Default Re: Boost/load targets on new 3port EBCS and turbo
    Don't think lex is on this forum
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Whoops! My bad. Edited.
    Member fywdyl's Avatar
    What RPM range does this happen at? What happens when you run spring pressure (e.g. 0 WGDC)?
    that's what she said...
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Its basically across the whole rpm range. I was running like almost 0wgdc when we did our first run and made ~9-10psi. Boost pressure and flow is rising as i increase the wgdc table. But im just now making 18.2 peak 17.1 hold psi on wgdc thats very close to what my original one was before these. Ive always been told you have to halve wgdc when you run 3 port on the ebcs. So im surprised that my numbers are low given how high i am now.
    My current wgdc table is close to this one, (current is slightly lower numbers in the midrange)
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Ill upload my last log when i get home tonight. Gonna try a boost leak test this weekend and see if im leaking anywhere but ive never had boost leaks before @20psi and ive got my share of practice taking the top end of my engine apart
    Do you know what your spring pressure is suppose to be?
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Stock k04 actuator still. So around 7-9 isnt it?
    Yeah that's right then. Do a boost leak check to make sure.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Ill do that this weekend. SomeGuy thinks it could also be an issue with tapping my boost reference from the back of my bpv and not the port on the turbo housing. Possible that with my boost sender and that i may have too many taps from that boost/vac source or too much hose.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    datalog8.csv
    Here are the logs with the latest map.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    It's actually painful to see that torque number >_<
    295 Post(s)
    Quote Originally Posted by DLYDRVN View Post
    I re-thought that, it shouldn't matter...running 3 port you remove all pressure from the wastegate when at 100% WGDC so it (wastegate) will stay completely closed. Your tap would only matter if you were creeping. That said, it could be causing your bypass valve to open since you're venting the boost source that's supposed to keep it closed. That wouldn't show up in your trims or AFR and wouldn't show up with a boost leak test.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Ok.. This makes sense.. the BPV still chirps when i let off boost, but i guess it's still _making_ boost, jsut not ENOUGH... it's leaking more than fully open.
    It's cobb's schematic, but maybe this weekend i'll go back to 2 port mode _first_... We may have made a fundamental mistake of doing two big mods at one time.. now we have to possible problem sources to hunt down.
    MajesticBlueNTO's Avatar
    May 2004
    49 Post(s)
    You should take the boost source for the EBCS from the turbo side and not at the bpv. One of the reasons is that there's up to a 2 psi drop across the intercooler.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Of course. That makes too much sense. So ill flip that and bring wgdc back down again and log and see whats up
    295 Post(s)
    Quote Originally Posted by MajesticBlueNTO View Post
    It shouldn't make a difference for low boost though...in 3 port mode you are either shunting air to open the wastegate (decrease boost) or shunting air to the intake (increase boost)...essentially anyway, since we know the valve is proportioning the air between the two. In any case, at 100% WGDC target all air goes back to the intake meaning there's nothing to force the wastegate open at all and he should be able to make the maximum boost possible on the turbo. If he was having boost creep issues though, ie the wastegate can't open enough to bleed off air then the 2 psi would definitely make a difference.
    Correct me if I'm wrong though, I always get the ebcs/wastegate/wgdc stuff mixed up in my head when it comes to what is practically happening.
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Doesnt it work the other way round. Like the bpv, boost holds the wg closed to assist the spring. Otherwise spring pressure wouldnt be a thing since the waste gate itself is normally closed.
    In this case i make low boost ok, but im atruggling to make anything above 14psi. Its really gotta work and build up to it to make 18.
    295 Post(s)
    The wastegate actuator pushes the flapper open...the push is provided by pressurized air. The spring holds back ~7psi or whatever, and once there's more than that 7psi on the wastegate actuator it overcomes this spring and starts to force it open. This is why we bleed off air to the intake, keeping pressure off the wastegate actuator so it remains closed for longer.
  20. The Following 2 Users Say Thank You to SomeGuy For This Useful Post:
    greyseason (08-28-2014),mickey_g (08-28-2014)
  21. #20
    May 2013
    Toronto/Kitchener
    110 Post(s)
    So im still thinking my best plan for this weekend is to go back to 2port mode and make sure i can make boost targets on the new turbo. Then move the ebcs back in the mix next weekend.
  22. #21
    295 Post(s)
    Yup, I agree that going back to the old style boost control is a good first step...I still think a boost leak test is in order though.
  23. #22
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Worth a shot... but i can hold stable boost... it's just holding low. I'll flip back and start back at the 1/2 wgdc map... See what i make. and ramp up from there.
  24. #23
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Ok. Went back to 2 port and found and fixed a small boost leak... And now, suddenly, im making 20.5psi and flowing 278g/s... Not sure if the boost leak was the only culprit. May attempt 3 port this afternoon and see how it goes
  25. The Following 2 Users Say Thank You to DLYDRVN For This Useful Post:
    Fobio (08-29-2014),greyseason (08-30-2014)
  26. #24
    May 2013
    Toronto/Kitchener
    110 Post(s)
  1. Speed Boost / Performance Increase without Turbo?
    By Tsirpas in forum Performance
    Last Post: 04-04-2009, 01:33 PM
  2. Boost Targets Q
    By spd frk in forum MazdaSpeed 3 Forum
    Last Post: 02-19-2009, 08:40 PM
