Results 1 to 8 of 8
Thread: Brake pad help
    Jr Member crasth's Avatar
    Mar 2014
    54 Post(s)
    Default Brake pad help
    So i ordered some brake pads and rotors frok my ms3 but i noticed some abnormalities. The outter pad doesnt have the part to hook the retaining clip, these also came with a wire and a connector ans i dont see that mine or the aftermarket have these. They are promax. I looked up on their website the part number and it says its for speed but im confusedq
    2010 CWP ms3
    ENGINE
    -corksport stge 2 sri + tip,cpe hpfp,cobb ap,turbosmart BOV 50/50,jbr boost tubes,bpv hose
    SUSPENSION
    -H&R lowering springs, koni yellow shocks
    294 Post(s)
    Default Re: Brake pad help
    Don't buy cheap shitty brakes? Stick with OEM...or at least centric blanks and hawk/ebc/corksport pads.
  3. The Following User Says Thank You to SomeGuy For This Useful Post:
    Girds (10-18-2014)
    Oct 2012
    Durham
    Following the above advice will fix your confusion. If they have a wire on them they are probably for something German.
    Sr Member silverstarmazda's Avatar
    Dec 2011
    scar-BRUH
    97 Post(s)
    you have the one for the audi, i got the same. as for the backing clip....it should be there
    50 shades of silver
    Mar 2014
    54 Post(s)
    I guess its time to give them back and get some good stuff. I even ordered hawks but my buddy hooked me up with these pads and the rotors for a ridiculous cheap price so i couldnt ket that go. Only if they fit lol. Bow regarding the disks, sorry fir the ignorance but how do i know if they fit, i tried them on and they fit but how do i really know if theyre for my car
    Dec 2011
    scar-BRUH
    97 Post(s)
    compare them to the old ones? the mazdaspeed rotor is 320mm in diameter, thickness around 25mm and a height of 49mm (manufacturer may vary slightly). the BIG give away is the bolt pattern which should be 5x114 with a centre bore of 72mm
    i might have to trade in my audi front pads because they are giving me fitment trouble... even though they should work...for some reason they are too thick
    Mar 2014
    54 Post(s)
    Quote Originally Posted by silverstarmazda View Post
    Yeah i know but i didnt compare them when i had the old one off. So i wanted another way. Ill measure it and make sure it works
    Dec 2011
    scar-BRUH
    97 Post(s)
    okay as for my fitment troubles. it seems as though the audi pads i got (although identical in shape) is just aliiiightly thicker than what the speeds use (at least on my brand of pads). the audi pads i got are 0.06in thicker than the speed 6 (known compatible). thats 3mm of extra pad material and it was seizing my rotor stiff.
    so in the end, dont use the audi pads even though they look the same
  1. Loose Brake Pad
    By Patches_O'Houlihan in forum Suspension & Brakes
    Last Post: 06-03-2013, 08:40 AM
  2. Brake pad improper wear?
    By grex in forum Suspension & Brakes
    Last Post: 08-23-2011, 03:26 PM
  3. Brake pad and rotor install!
    By dhawtin in forum Suspension & Brakes
    Last Post: 06-06-2009, 10:14 PM
  4. Brake Pad choice.
    By garboui in forum Suspension & Brakes
    Last Post: 11-21-2007, 09:54 PM
  5. Brake pad wear
    By sbmonkey in forum Performance
    Last Post: 11-16-2006, 12:46 PM
