Recently I had new rims and tires put on my car. The other morning I thought they looked a little low and when I checked the pressure they were all at 32 psi. The sidewall of the tire says to put in a maxumum of 51 psi. What\'s the correct amount of air you should have in your tires? Is there a set amount under the maximum you should stick to? I assume that the guys that mounted the tires thought 32 psi was enough, was it? I realize the more air you have in the tire, the harder the ride, but you\'d get better mileage as well. This is my first set of performance tires so I\'m new to the game. Usually I keep my all season tires just under their maximum psi allowing for a little expansion when they warm up.
What\'s the deal?
