Results 1 to 20 of 20
Thread: stock HID not firing
    Moderator loki's Avatar
    881 Post(s)
    Default stock HID not firing
    Anyone having issues with their stock HIDs in the colder weather?
    My left hasn't been firing up. At first it would just need the car to run for a few minutes but now it just won't fire up. It will flicker when first turned on but that's it
    Couple things to note..
    1. I no longer do the auto light setting so I can turn on the lights after the car is on
    2. I have a slim battery to fit my intake
    Sr Member jay93's Avatar
    Oct 2012
    t.o./mississauga
    49 Post(s)
    Default Re: stock HID not firing
    Slim battery? (ballast)? Try switching the ballast. Try the passenger one on the drivers side. That could be your problem. It could also be that the bulb is starting to die.
    IG: 2pointlow
    881 Post(s)
    Quote Originally Posted by jay93 View Post
    Battery
    Sr Member silverstarmazda's Avatar
    Dec 2011
    scar-BRUH
    97 Post(s)
    what are the specs of the slim light weight battery at normal temps? thought slim batteries were rated lower than regular batteries.
    i would get another member with OEM hids and swap them over and see if its a component issue
    50 shades of silver
    Member trulankan's Avatar
    Mar 2012
    32 Post(s)
    haven't had any problems with mine (knock on wood)...if you are not having any problems cranking its prob not the battery. if its been working fine since the battery switch then its probably the bulb or ballast.
    Uncle Ben
    Sep 2005
    The mazda ballasts and ignitors are rather bullet proof, more than likely your bulb is on the way out. If you take the bulb out you will see a little glass ball in the middle. Generally they are clear/yellowish, if it is black then the bulb is gone.
  7. The Following User Says Thank You to McGuyver_3 For This Useful Post:
    loki (12-28-2014)
    881 Post(s)
    Will check out the bulb when I get back to T.O
    It was playing the fool for a bit last winter as well which had me curious about the cold and ability of my smaller battery to fire it up
    Oct 2012
    t.o./mississauga
    49 Post(s)
    okay, excuse me on this one. but what battery? like the car battery? if it's a different battery can someone post a picture?
  10. #9
    Car battery. Some big turbo applications of the Speed3 use a smaller battery to allow more space for go fast parts.
  11. The Following User Says Thank You to S.F.W. For This Useful Post:
    jay93 (12-28-2014)
  12. #10
    Oct 2012
    t.o./mississauga
    49 Post(s)
    Thank you! my opinion is that it's most likely the bulb. If it was flickering and became more faint in time.
  13. #11
    Jr Member Cyclic's Avatar
    May 2010
    25 Post(s)
    Correct me if I am wrong but I'm pretty sure HID bulbs don't completely go out when they die. They still light up but very faint. When my bulb started to die it would ignite to the it's full brightness then gradually dim after a minute to about as bright as a stock interior dome light. Eventually it just started up to the faint glow right off the bat. I would think the ballast is the issue unless the bulb was cracked or something.
    2005 GT GFX Black Mica
    2015 GT Aerokit Snowflake White Pearl
  14. #12
    Member Canadianbacon's Avatar
    Mar 2013
    East York
    51 Post(s)
    Also doesn't it change colours when its on its way out? I seem some purplish and other normal on roads
    2010 GT MZ3 2.5 MSDS Headers, Custom Tune, CS SRI,CS Full CBE,CS LED conversion, 3K HID fogs, 15%Tints,Koni Str.T H&R Sport Lowering Springs, Speed3 Rims, duel 12''MTX subs, Vinyl Wrap Roof,Mirrors,Spoiler
  15. #13
    Uncle Ben
    Sep 2005
    Quote Originally Posted by Canadianbacon View Post
    Quote Originally Posted by Cyclic View Post
    You are both correct, they do change colour over time. However they tend to change colour equally and you do not notice until you change the one how different the other one is. But when they die, they have all differen't kinds of scenarios. Some turn on and shut off after a few minutes, some flicker but fail to stay on, some turn dark purple and are useless to see out of. At work I have seen alot simply do nothing, not even attempt to igite the bulb.
  16. #14
    881 Post(s)
    Quote Originally Posted by McGuyver_3 View Post
    So what you're saying is if it is in fact the bulb I should probably change both at the same time?
  17. #15
    May 2010
    25 Post(s)
    I would say changing both bulbs would be the best so that the colour matches on both sides. Unless you don't mind the slight difference of course.
  18. #16
    Uncle Ben
    Sep 2005
    well for the price of 85-90$(after conversion)
    found here
    http://www.ebay.ca/itm/2x-NEW-PHILIP...ht_1248wt_1362
    its not a bad idea to do both
  19. #17
    I say battery... the cold takes a bite out of the battery's reserve capacity... after a cold start on a cold day, there's not too much reserve capacity on a smaller battery
    as a troubleshooting step, try jump starting the car and see if this issue continues... if it doesn't, then it's the battery
  20. #18
    881 Post(s)
    Today and last night with the warmer weather, both lights fired up no problem
    I'm going to keep an eye on it but my suspicion has always been the battery
  21. #19
    Jan 2014
    How could the battery really affect the firing up though? If the car is already running when you turn them on the alternator should handle power demand shouldn't it? Unless there's a weak link somewhere in there? Have you tried cleaning the battery terminals?
  22. #20
    Quote Originally Posted by studum View Post
    Yeah if the weak link is the battery...A low (weak) battery will draw more power from the alternator. This could be a substantial amount of the alternator's capacity. Not saying it is the battery causing the issue there could be several, including frozen ballasts, but could very well be.
  1. Stock HID highbeams vs -29°C malfunction?
    By kheaz in forum Problems with the Mazda3
    Last Post: 02-06-2015, 03:34 AM
  2. Stock to HID's
    By EricTheRed in forum Lighting, Electrical & Security
    Last Post: 11-27-2011, 07:56 PM
  3. stock HID's on MS3
    By redwun in forum MazdaSpeed3 Stock Issues
    Last Post: 10-30-2011, 01:24 AM
  4. Stock HID Issues
    By Gareth232 in forum Electrical
    Last Post: 10-11-2010, 10:55 PM
  5. HID firing issues
    By McGuyver_3 in forum Lighting, Electrical & Security
    Last Post: 02-26-2007, 07:59 PM
