Results 1 to 25 of 44
Thread: RSB Bracket Broke AGAIN - Looking for replacement options
    Member fywdyl's Avatar
    Angry RSB Bracket Broke AGAIN - Looking for replacement options
    Planning to replace the brackets with something that won't break, so sick and tired of them breaking and the clunking.
    I've found 2 options so far, are there any other recommendations?
    Corksport:
    http://corksport.com/mazda-billet-sw...-brackets.html
    (not sure if the bushing will fit around the JBR sway bar, I couldn't find the diameter anywhere on the website)
    JBR:
    http://www.jamesbaroneracing.com/sho...2nu4mde470o6g0
    (looks like overkill to me, but at least it will fit for sure... but an extra like $25 to ship to Canada...)
    Thanks.
    that's what she said...
  2. The Following User Says Thank You to fywdyl For This Useful Post:
    Elusivellama (02-22-2015)
  3. #2
    Member Lmmorden's Avatar
    Jan 2014
    51 Post(s)
    Default RSB Bracket Broke AGAIN - Looking for replacement options
    I'd get JBR
    Edit: may be overkill but you did blow a bracket twice
  4. The Following User Says Thank You to Lmmorden For This Useful Post:
    fywdyl (02-08-2015)
  5. #3
    Default Re: RSB Bracket Broke AGAIN - Looking for replacement options
    I'd get JBR
    True, but the bracket alone will cost like more than half of the swaybar, haha.
  6. #4
    294 Post(s)
    I would question why are you breaking them in the first place? Is there something damaged/worn out with your suspension?
  7. The Following 2 Users Say Thank You to SomeGuy For This Useful Post:
    fywdyl (02-08-2015),Lmmorden (02-08-2015)
  8. #5
    Newbie murdaspeed's Avatar
    Jun 2011
    SW Brampton
    15 Post(s)
    Are these breaking due to stress on the brackets, corrosion, or both?
    Tuning by MSPEED Tuning & Diagnostics
    26psi
  9. The Following User Says Thank You to murdaspeed For This Useful Post:
  10. #6
    Jan 2014
    51 Post(s)
    Did you install your rsb? Is it stock ? What are you running and how is it adjusted?
    The few chimes are right.. Two brackets does seem odd
  11. #7
    Sr Member Kiyomi's Avatar
    115 Post(s)
    if you buy a new sway bar from cs, they come with these brackets now. think of it as getting a new sway bar for about half price with the brackets you want.
  12. #8
    Member ottoyu34's Avatar
    Jun 2011
    Markham
    38 Post(s)
    then sell your old one for cover up cost.
    2010 Mazda 3 GT Sedan - Graphite Mica
    | Enkei Raijin+Michelin PSS | Rays lug nuts | RoadMagnet+Koni Yellow | SPC Cam.Arm | CS F Strut bar+MidBrace | JBR RSB | CS SRI+AirBox | Racing Beat Exhaust | Amsoil Signature Series 0W20&ATF | CS LED Light kit | CS LED DRL | Corksport LED fogs | Smoked Head & Tail Lights | CS LED 3rd brake | LED Projector Reverse light | FormulaOne Pinnacle series tints | Mazda3 Weathertech Floorliner & Trunkliner | Scuff Plates | Window Visors | OEM Side Skirts | Bosch Icon | CS Tow Plate | CS Hood Dampers |
  13. #9
    Jan 2014
    51 Post(s)
    Quote Originally Posted by ottoyu34 View Post
    ...If it's not bent...
  14. #10
    I don't swing that way, I'm straight... come over and find out....
    JBR RSB, yes I installed it, yes I jacked up the wheels when mounting the sway bar. It is set on the middle setting.
  15. #11
    How would I go about diagnosing? I mean, the car drives fine, but it's not like I'm taking every corner super duper hard.
  16. #12
    Member Canadianbacon's Avatar
    Mar 2013
    East York
    51 Post(s)
    I just ordered the CS RSB glad they included the brackets $80 vaule since mid January Now. Good deal!
    2010 GT MZ3 2.5 MSDS Headers, Custom Tune, CS SRI,CS Full CBE,CS LED conversion, 3K HID fogs, 15%Tints,Koni Str.T H&R Sport Lowering Springs, Speed3 Rims, duel 12''MTX subs, Vinyl Wrap Roof,Mirrors,Spoiler
  17. #13
    Jan 2014
    51 Post(s)
    Woah.. What are you thinking about?
  18. #14
    Whatever you have in mind... I'm open to suggestions...
  19. #15
    294 Post(s)
    Check the shocks aren't leaking. Check all the bushings for wear/play. Check everything is tight. Are you on coils or anything? Change dampening settings?
    There shouldn't be much stress on those brackets which is why I'm surprised you've broken a couple.
    Also, you can buy the Energy bushings/brackets off amazon.ca for around 30 bucks.
  20. The Following User Says Thank You to SomeGuy For This Useful Post:
    fywdyl (02-08-2015)
  21. #16
    Stock suspension except for RSB. No leaks from the shocks (at least from what I can tell). Haven't checked bushings.
  22. #17
    Jan 2014
    51 Post(s)
    Are the brackets big enough for the upgraded bar?
  23. #18
    Feb 2008
    Really ? Pretty sure the rate of that bar is over 1,000lbs. A lot of that force goes into the brackets trying to keep the bar in place.
    Reference EG/EK/DC2 Honda/Acura sway bar mounts tearing from the subframe after upgraded RSB. Pretty sure E36 BMW have simliar issues.
  24. #19
    Came with the set, wouldn't make sense if it wasn't.
    Read on msf that it is a common problem and even Jamie himself said that it's the weakest part.
  25. #20
    294 Post(s)
    Quote Originally Posted by speed77 View Post
    I mean it's not taking as much as say a control arm...yes of course there's stress. That said, I've yet to see broken brackets on any of the cars I've worked on which is why if he's broken another set I wonder if something else is wrong causing additional stress to the component.
  26. #21
    Jr Member miako's Avatar
    Sep 2010
    C400
    33 Post(s)
    I ordered the jbr sway bar with the aluminum block bracket, had it installed by jimmy like early last year. No problem so far, I had the bar set at the stiffest setting. Imho, the upgraded bracket is well worth the money
  27. #22
    115 Post(s)
    Quote Originally Posted by miako View Post
    @miako ,did you get the competition bar or the .120? and if the .120, are you able to oversteer much?
  28. #23
    Sep 2010
    C400
    33 Post(s)
    Quote Originally Posted by Kiyomi View Post
    I have the 125 bar, not the 250 competition
  29. #24
    Jan 2014
    51 Post(s)
    So what's the scoop?
  30. #25
    Most likely going w/ JBR, less fuss with fitment and what not.
    Not gonna order it anytime soon, waiting until winter is over.
  1. RSB Brackets
    By fywdyl in forum MazdaSpeed 3 Forum
    Last Post: 10-12-2013, 11:58 AM
  2. replacement bushings for corksport rsb in GTA
    By VQ Junkie in forum Suspension & Brakes
    Last Post: 10-10-2012, 11:28 AM
  3. Windshield broke. Replacement time?
    By Shawn in forum Mazda3 General Discussion
    Last Post: 10-19-2011, 07:58 AM
  4. 2009 GT Sedan Bumper Replacement Options
    By asmo in forum Exterior Styling & Appearance
    Last Post: 08-02-2009, 05:15 PM
  5. Hi-Beam bulb replacement options??? (for 08+)
    By Mafty in forum Lighting, Electrical & Security
    Last Post: 08-07-2008, 06:18 PM
