Results 1 to 25 of 28
Thread: Brake options ( Rotors & Pads)
    389 Post(s)
    Default Brake options ( Rotors & Pads)
    I need to replace my rotors and pads in the near future. Have done some reading, but not much consensus to be found.
    The car is a fun daily driver, and is going to likely see it's first bit of track time this year.
    I have no interested in slotted or drilled rotors, as I don't see a major benefit.
    Rotor wise I was leaning towards OEM, but have read some good things about Centric. Other ideas ?
    Pads are a tough call, I really like the bite of OEM, but hate the dust. Had Hawk HPS on my old 3, and missed the initial bite of OEM. OEM pads are also expensive.
    Am thinking of the Stoptech Posi Quiets..
    Member ottoyu34's Avatar
    Jun 2011
    Markham
    38 Post(s)
    Default Re: Brake options ( Rotors & Pads)
    Have you looked into EBC's offering?
    2010 Mazda 3 GT Sedan - Graphite Mica
    | Enkei Raijin+Michelin PSS | Rays lug nuts | RoadMagnet+Koni Yellow | SPC Cam.Arm | CS F Strut bar+MidBrace | JBR RSB | CS SRI+AirBox | Racing Beat Exhaust | Amsoil Signature Series 0W20&ATF | CS LED Light kit | CS LED DRL | Corksport LED fogs | Smoked Head & Tail Lights | CS LED 3rd brake | LED Projector Reverse light | FormulaOne Pinnacle series tints | Mazda3 Weathertech Floorliner & Trunkliner | Scuff Plates | Window Visors | OEM Side Skirts | Bosch Icon | CS Tow Plate | CS Hood Dampers |
    May 2012
    51 Post(s)
    Aftermarket pads (anything) are expensive with our dollar right now... I would go with OEM pads and NAPA premium rotors.
    389 Post(s)
    Quote Originally Posted by pwdunmore View Post
    @pwdunmore actually I think aftermarket even with the dollar is less expensive than OEM. OEM have an MSRP ~$250 for the front and ~$200 rear.
    Member Scottobot's Avatar
    Apr 2008
    Orangeville
    I have those on my Speed3 and I really like them.. significantly less dust than OEM. I also switched my rotors to slotted Centrics at the same time. With the combo I noticed braking has much less initial bite and but is very progressive. I have had to make a few emergency stops and they worked well to say the least.
    Jr Member ptfire's Avatar
    Oct 2007
    I changed rotors and pads last year for the first time on my 2007 MS3. Because the OEM rotors served so well I decided to stick with what has worked, the price is very reasonable too. I changed the pads to Stoptech which I purchased from CTA Motorsports. I am happy with this setup and am sure they will serve trouble free for a number of years.
    Jr Member mickey_g's Avatar
    Apr 2012
    Mississauga, ON
    44 Post(s)
    Also look into ebc redstuff they are supposed to be good pads for dd with occasional autox and track. For rotors I would go with centric blanks. Not sure if you are getting the brake fluid changed but thats something to look at as well.
    Look at the packages at knsbrakes. They have a good selection and very competitive pricing.
    Moderator loki's Avatar
    865 Post(s)
    I have oem rotors with stoptech pads and I'm happy
    Member Zuluwun's Avatar
    5 Post(s)
    Really enjoying my OEM rotors + EBC yellows. Performed great while autocrossing and well mannered on the street, even in winter.
    May 2012
    51 Post(s)
    Just keep in mind dollar sucks... OEM is expensive as usual. Edge has EBC OEM spec pads that are cheap, kinda interested to see if they are good or not.
    Sr Member zzz3's Avatar
    May 2010
    31 Post(s)
    Set of ms3 front Stoptech slotted rotors and pads will set you back under $300 shipped from rock auto. I have been happy with this combo thus far.
    Jr Member betterthansx's Avatar
    Burlington
    23 Post(s)
    I am in the same boat here and am not sure what to go with. I will be doing a handful of track days this year. My biggest worry is glazing the pads.
    JRP quoted me $750 for Stoptech Sport Kit which is Stoptech/Centric Slotted rotors front and back, Stoptech Street Performance pads front and back and braided brake lines front and back. Does anyone have this and use it for track duty? Should I be looking at something else?
    "A car is just fast enough when you stand in front of it in the morning and are afraid to unlock it" -Walter Rohrl
    286 Post(s)
    I'm on OEM rotors with Corksport pads...quite happy.
    389 Post(s)
    Quote Originally Posted by betterthansx View Post
    For a handful of track days do you really want to spend the money on upgrading your lines ?
    I should research the CS pads, haven't read that much about that setup.
    286 Post(s)
    I like them better than Hawk HPS pads...they've got a bit more bite, not quite OEM, but good enough to give you confidence. Along with the typical lack of fade, dust, noise and such that you want. I'd buy them again.
    Jun 2011
    Markham
    38 Post(s)
    This could be good reading material to help with all your braking needs:
    http://oppositelock.jalopnik.com/bra...-st-1688020147
    Burlington
    23 Post(s)
    Why wouldn't you for how simple the install is?
    389 Post(s)
    More fragile than OEM, harder to diagnose issues such as leaks.
    Sr Member rzapata's Avatar
    Jan 2011
    Downtown TO
    35 Post(s)
    I got HPS pads front and rear, front DBA slotted rotors (something with kangaroo paw), OEM rear rotors.
    Worked well for me especially during sudden hard braking. Haven't locked the brakes, not even once.
    HPS pads as you mentioned didn't have the initial bite, but I think I can live with that.
    12 Post(s)
    I just got Front and Rear OEM ATE pads from Rock Auto shipped to my door for $169. The $169 included the 20% US to Can conversion, shipping, taxes, customs/brokerage fees and anything else they charged. Not bad considering the stealership quoted me $375 plus taxes. When I ordered they said it would be almost 2 weeks (April 6th was my delivery day) and they arrived today...wow.
    Burlington
    23 Post(s)
    To those who have used the EBC Yellowstuff, how would you compare them to OEM? I used EBC pads on my bike and they were amazing. The best out there in my opinion, but I do not know anyone who has used their automotive pads.
    Sep 2013
    I just ordered this kit. Price is comparable to other options. Anyone have questions/comments/concerns or a review on either the brakes or the company?
    I'll give my thoughts upon delivery and install.
    389 Post(s)
    I ordered stop tech high carbon rotors and hawk 5.0 pads
    5 Post(s)
    Hey, just saw this. I'm running EBC Yellows on OEM rotors for autocross and street.
    Compared to OEM, I'd say they have a very slight disadvantage in initial bite but quite a bit more ultimate stopping power. Haven't yet gotten them to fade but I've also never tracked; most heat I've gotten into them was probably on a twisty back road, autocross doesn't heat them all that much.
    They dust as much if not a bit more than OEM. Ran them through the winter and the cold didn't seem to affect their performance during the warm up period. They squealed a bit after install but after the break in period it became much less frequent. Overall, I'm really happy with them for what I use them for.
    Newbie ach's Avatar
    11 Post(s)
    hey @S.F.W., I'm in the market for rotors and pads for my MZ3 and came across this thread. How do you find the stop tech / hawk 5.0 combo on your MS3? And where'd purchase the parts from? Thanks for your help, Ami!
  1. Brake pads + rotors
    By cSPEED in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 04-19-2013, 07:05 PM
  2. Silverstone Brake Rotors & Pads? Anyone Tried em?
    By PKock in forum Suspension & Brakes
    Last Post: 05-24-2012, 12:00 PM
  3. Brake Rotors Have Ridges...Are my brake pads digging in?
    By adubya in forum Suspension & Brakes
    Last Post: 06-04-2011, 09:45 AM
