My 2007 Mazda 3 GT Hatch drivers side bulb burnt out. Where can I buy a replacement locally in Scarborough?
2007 Mazda 3 GT 2.3 Hatch GT--Meteor Grey, Magnaflow Exhaust, Kenwood DDX 793 Indash, 600 watt Hertz 10" Sub, 500 watt alpine amp. 3000K Fogs
Any major parts store will stock them. If you're looking for a decent set, i highly recommend the Morimoto D2S 35W XB35 series bulbs. Replace them in pairs. if you go aftermarket on one of them, chances are they will never look the same.
XB35's are about 70$ shipped for both, where as OEM ones run about 200+ at the dealer, and Aftermarket replacements run about 100-135 depending on your place of purchase.
____________________________________
2011 Celestial Mica Blue Mazda 3 GS Sport
2.5L 6 Speed Manual
DC Sports Intake, 5.5K Morimoto Retrofit HID kit, Sure Motorsports RMM
Enkei Wheels,R40 lug nuts, ISC N1 coilovers, Corksport short shifter, CS Rear sway bar
Ebay front strut bar, Custom magnaflow axleback w/ 4" tips, Style M front lip
Since you have HIDs: be advised: you'll have to pull the bumper cover off and remove the headlight assemblies from the car in order to change out the bulbs. Not terribly difficult to do, but it is easier if you have a second set of hands.
... which is why you'll need the pull headlamp assemblies. There isn't enough clearance at the back to remove cover, and then reach inside to pull out the the connector and then bulb. The original design only allowed for halogen bulbs, which don't protrude out as far at the back as the HIDs. The first gen 3s were designed with halogen bulbs in mind -- the HIDs were added later and have larger headlamp assemblies.
tester2013 (04-11-2015)
Just dont take it to the dealer. They'll charge you $100 to change a bulb lolll
Too Many Mods To ListPicture Gallery: http://www.torontomazda3.ca/forum/sh...ad.php?t=37634
By the way does the 2007 Mazda 3 GT come with HIDs from the factory?
