Results 1 to 17 of 17
Thread: Shocks, Struts, and End Links
    Member fywdyl's Avatar
    Default Shocks, Struts, and End Links
    Hey guys, need some advice.
    Went to Jimmy's today to have him diagnose a noise. Turns out my driver rear end link is toast and as is my passenger rear strut.
    Any recommendations for brands or where to buy from? (I'm thinking Bilstein) Would you recommend getting springs as well or would it be fine sticking with the stock springs?
    I don't care to drop the car, I just want a good balance of mostly DD use and like the occasional track day here and there.
    Thanks!
    that's what she said...
    Moderator loki's Avatar
    873 Post(s)
    Default Re: Shocks, Struts, and End Links
    Might as well change the springs at the same time, apart from the cost of the springs, labour won't be anything extra if you're already doing the struts.
    You don't need to go with anything too aggressive, but upgraded springs would improve the handling and a less aggressive spring would still provide the comfort
  3. The Following User Says Thank You to loki For This Useful Post:
    fywdyl (04-20-2015)
    Swift springs then?
    873 Post(s)
    Swift springs then?
    I like em'
    Dec 2012
    Halifax NS
    Pro kits are a moderate drop and u can go to the track on the occasion as well.
    Where to buy?
    873 Post(s)
    Where to buy?
    I bought mine through Alpha
    I think @S.F.W. picked his up somewhere else...
    OK, just ordered a set of MOOG end links from Rock Auto.
    I was reading some different threads from here, and Essex Distributors was mentioned to carry Bilstein stuff. Full set of shocks and struts are so expensive...
    I don't think I am going to shell out extra for the springs, UNLESS it is like detrimental if I don't get them or something.
  10. #9
    873 Post(s)
    It's not detrimental
  11. #10
    394 Post(s)
    Essex/Bilstein Canada is an option, as is Northern Performance. For the springs, I bought from Edge when the dollar was higher. They are not essential, but make a big difference.
    If you want to take my car for a drive before you decide just text me.
  12. The Following User Says Thank You to S.F.W. For This Useful Post:
    fywdyl (04-20-2015)
  13. #11
    Swap cars for the day, haha.
    @S.F.W. I may take you up on the offer.
    Also, in my cheapness I thought of something else I can do...
    Order 1 rear strut and get it replaced, since I have no plans to do springs.
  14. #12
    394 Post(s)
    If you are planning to upgrade the struts, or need something temporary, I have my stock struts sitting in storage.
  15. The Following User Says Thank You to S.F.W. For This Useful Post:
    fywdyl (04-20-2015)
  16. #13
    873 Post(s)
    Cheap?
    You married a suga momma!!!
  17. #14
    Cheap?
    Suga momma don't know about my spending habits.
    I think I'm going to go OEM cuz I haz no monies.
  18. The Following 2 Users Say Thank You to fywdyl For This Useful Post:
    loki (04-20-2015),shift8 (04-21-2015)
  19. #15
    One more question...
    When you guys did your suspension, did you replace anything else? (bump stops, etc etc)
  20. #16
    394 Post(s)
    No other changes. Bump stops are re-usable.
  21. The Following User Says Thank You to S.F.W. For This Useful Post:
    fywdyl (04-22-2015)
  22. #17
    294 Post(s)
    Bump stops and strut mounts are cheap from rock-auto if they're in rough shape. If you're paying someone to do it, I'd say get them now as it will save you labour later if one is on its way out.
    That said, rear struts are 3 bolts per side, very easy to change, about 15 minutes per side. Springs take a bit more time as they're done independently of the strut and you need to disconnect the RSB. Honestly there's nothing wrong with the stock MS3 suspension, I'm still running it short of an RSB and am plenty happy with how my car handles.
  23. The Following User Says Thank You to SomeGuy For This Useful Post:
    fywdyl (04-22-2015)
  1. Replies: 0
    Last Post: 07-11-2013, 01:17 PM
