Results 1 to 3 of 3
Thread: Front springs loose?
    Dec 2014
    Aylmer Ontario
    Default Front springs loose?
    So long story short. I bought new koni Orange shocks and struts and eibach pro kit springs. Once installed took the car for a drive and on the way home I heard a clunking sound. I put the car up on jacks and the springs are loose to the point I can spin them around on the strut. I've double checked all the part codes and everything checks out. So what I'm asking is Wtf has anyone else had an issue like this?
    Jr Member betterthansx's Avatar
    Burlington
    23 Post(s)
    Default Re: Front springs loose?
    There should be a little step in the perch that stops this from happening. Under no circumstance should the coil be loose.
    "A car is just fast enough when you stand in front of it in the morning and are afraid to unlock it" -Walter Rohrl
    Dec 2014
    Aylmer Ontario
    The spring is against the perch. I can spin the spring the opposite direction, but only when the car is in the air. Once the tires touch the spring is tight. The guys on the mazdaspeed forum said that the koni Orange are a longer shock and the pro kit springs tend to be a bit on the short side.
  1. Front passenger door handle loose
    By crunchie46 in forum Problems with the Mazda3
    Last Post: 05-30-2012, 09:23 AM
  2. Front Lip Coming Loose
    By Punkrockjohn in forum Exterior Styling & Appearance
    Last Post: 07-15-2011, 03:02 PM
  3. Front bumper coming loose
    By ieronimus in forum Problems with the Mazda3
    Last Post: 07-13-2010, 07:37 PM
