******DISCLAIMER: PICTURES PROVIDED FOR REFERENCE ONLY > THE KIT COMES WITH GOOD STEP BY STEP INSTRUCTIONS > PLEASE READ THEM ALL IN DETAIL******
I restored my headlights this past Saturday as 1 was beginning to haze and both looked quite rough after being weathered for 170K of driving.
The kit is available at Can. Tire for around $35 dollars.
Remove bumper if you feel the need to. It makes the process easier, will prevent damage to bumper and will make access to the lowest most corner of the lens much easier. I was short on time and was able to reach the corner of the lens just fine without removing the bumper.
You need:
- a drill with a pair of steady hands
- microfibre cloth
- paper towel
- extra masking tape (optional)
- spray bottle filled with water (optional)
- patience (not optional)
The kit includes:
(6) 500 grit sanding pads
(4) 800 grit sanding pads
(1) sanding pad attachment for drill
(1) roll of 3M masking tape
(1) 3000 grit wet sanding pad
(1) rubbing compound
(1) synthetic was sealant
(1) foam buffing pad
(1) INSTRUCTIONS
Time required: 2-3 hours. Don't rush. Be careful.
Difficulty: 2.5/10 (1 stickers and Plastidip, 10 engine swap)
BEFORE >
[IMG][/IMG]
PREP
Clean lens and Use all of the masking tape provided, then use even more. Unmasked areas will be damaged by the abrasive sanding pads. Also note that the tape will get wet in later steps so best use a lot. Its just masking tape, go nuts.
[IMG][/IMG]
500 GRIT
Detailed technique is outlines in the instructions. Slow and steady, back and forth motions preferred. There are 6 pads total, I used 3 each. Use paper towel to remove particulate and unclog pad (there was a lot of particulate) when needed and switch pads as they wear down and do not sand anymore.
This is the most discouraging step as the damage looks horrendous.
[IMG][/IMG]
800 GRIT
4 pads provided, 2 per headlight. Clear particulate from lens and pads with paper towel as before. Scratches begin to get finer, clarity improved.
(400 to 800)
[IMG][/IMG]
[IMG][/IMG]
3000 GRIT WET SANDING
only 1 pad provided. Keep wet by spraying the lens and pad with water. A white slurry will begin to appear, make 3-4 passes per lens.
scratches greatly reduced, clarity improving.
[IMG][/IMG]
RUBBiNG COMPOUND
Put dime sized amount on foam buffing pad, smear all over lens. finish buffing when hazy compound disappears. Repeat by adding another dime sized amount for added desired clarity. (no pictures) I was getting tired.
WAX SEALANT
Rub into lens with microfibre cloth. Immediately remove after application.
AFTER / RESULTS
It worked. I would recommend this product provided you have all the tools, read the instructions and do not cut corners.
The photos do not do the new clarity justice. The lenses look very clear and are smooth to the touch.
I will update how the headlights look in the coming months.
[IMG][/IMG][IMG][/IMG]
Good luck, feel free to PM for any questions.
