Results 1 to 18 of 18
Thread: Twhite71 Logs
    Newbie Twhite71's Avatar
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    Default Twhite71 Logs
    Ok so i finally figured out how to do these logs as I'm new to the AP V3.
    Mods:
    corksport cat-back exhaust (have catted downpipe but not installed until i get a HPFP)
    corksport TIH and short ram intake
    Tune: Stage 1 + SF
    if you guys could review and make sure everything looks okay.(fingers crossed)
    i had a Fuel to rich yesterday but hasn't come back.
    Attached Files Attached Files
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    Default Re: Twhite71 Logs
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Dude, you need to do a proper 4th gear wot run for a proper log.
  4. The Following User Says Thank You to Fack_Dude For This Useful Post:
    boyracer (07-11-2015)
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    Okay. Lol I will attempt this again tonight after work.
    IG: Countryboy_MS3
    Moderator loki's Avatar
    865 Post(s)
    as fack_dude eluded to, you only made it up to 4700 rpms
    You could do a 3rd gear pull with your mods, but right to redline
  7. The Following User Says Thank You to loki For This Useful Post:
    Twhite71 (07-10-2015)
  8. #6
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    July 10th 2015.csv
    so I've attempted to do this better did it on a 3rd gear pull
  9. #7
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    im gonna do another one tonight when its a bit cooler outside.
  10. #8
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
  11. #9
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
  12. #10
    Sr Member Kiyomi's Avatar
    115 Post(s)
    wholy log batman. choppy. looks like ur knock happens right before spool up.
  13. #11
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    Quote Originally Posted by Kiyomi View Post
    yeah i did it and forgot to stop the log after a bit so it went for a while lol.
  14. #12
    115 Post(s)
    Quote Originally Posted by Twhite71 View Post
    its only happening at low load. specifically at 0.5-0.75 maybe try lessening your intake advance a bit in those areas. is it boost or load based tune?
    its happening quite often which is not good. because its happening not at wot but near cruising, you might wanna fix it asap.
  15. #13
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    its happening quite often which is not good. because its happening not at wot, you might wanna fix it asap.
    Was using the COBB OTS Corksport stage 1 + CRI + TIP.
  16. #14
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    going to reflash to Stage 0 to see if it helps, still waiting to install internals
  17. #15
    115 Post(s)
    why not just fix it? do your own map.
  18. #16
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    If i only knew how to. not that technical with the tuning yet
  19. #17
    Mar 2013
    2010 Mazdaspeed 3
    17 Post(s)
    Can someone review this log to see if i possibly have internals, i was told by someone that i might have it already. i never added it in after i bought the car, pervious owner could have done it though. dont really want to pull it out and apart to find out unless im going to be putting one in.
  20. #18
    865 Post(s)
    fuel pressure looks good. Almost hitting 2000psi...
    Impossible to tell for sure if there are internals without pulling it apart and taking a look
  1. Twhite71's speed 3
    By Twhite71 in forum Member Rides
    Last Post: 05-12-2017, 02:57 PM
  2. My Logs
    By Booostin in forum MazdaSpeed3 Tuning
    Last Post: 10-17-2012, 02:16 PM
  3. Thrizzl3's logs
    By Thrizzl3 in forum MazdaSpeed3 Tuning
    Last Post: 06-08-2012, 05:07 AM
  4. caq's logs
    By caquricon in forum MazdaSpeed3 Tuning
    Last Post: 10-18-2011, 01:44 PM
  5. Some DH logs
    By TriniFyah7 in forum MazdaSpeed3 Tuning
    Last Post: 10-14-2011, 02:22 PM
