I have a 6 month old 2015 Mazda 3 Sport GS and when I was on my way home today,
(Sorry, accidentally hit a key and this posted before I was finished)....
Continued -
I was on my way home and tried to put the passenger window down but it got stuck. By stuck I mean that the motor seemed to be working and the window did go down by about a cm but would stop after that... Anyone experience this issue?
Thank you in advance!
PS. Will post an intro post soon!
Try and reset the upper lower limits of the window. Press the button and hold for a few more seconds after the window stops. Go up and hold.... Down and hold.... then try all the way up and all the way down again to see if this fixes the problem.
If it does not, take it back to the dealership to be fixed under warranty.
I have a 2014 and I've been having the same issue on and off. Just tried to do this reset thing a few days ago. If it happens again, I'll be taking it back to the dealership.
It's your driver side switch board, motor is running fine. The switch board is 140, simple and easy to do it yourself. Unfortunately you can't buy each switch, it's the entire unit.
It's basically wear and tear, magnetic strip has been worn down. Sometime it works and sometime it won't.
Yup all the time. Always after washing car also.
2015 Mazda 3 Sport
Anyone get this replaced under warranty?
Not sure if this is in the warranty, but it's an easy fix.
Make a call and find out?
