Results 1 to 11 of 11
Thread: Motorcycle Shops?
    Aug 2013
    14 Post(s)
    Default Motorcycle Shops?
    I recently got a motorcycle and was wondering if anyone knows any good garage for it?
    Jun 2015
    Default Re: Motorcycle Shops?
    What area do you live in/near and what do you ride?
    mark
    Aug 2013
    14 Post(s)
    Quote Originally Posted by Darth Maz View Post
    mark
    I live in Markham. Got a ninja 250.
    129 Post(s)
    Download a haynes maunal and get some tools. For the most part and simple maintenance even our 600s are easy to work on. For things like internal engine work. Id let the pros do it.
    Sr Member dentinger's Avatar
    May 2007
    Edmonton, AB
    12 Post(s)
    remove the battery/gas in the winter, and oil changes at the start of every season.
    all i ever did to mine.
    I guess I should also rename the Engine/Drivetrain section "Arts & Crafts"
    2007 Mazda3 gx
    2003 Volkswagen GTI 20th Anniversary Edition
    2010 Kawasaki Ninja 250R
    2011 Dodge Ram 1500 Outdoorsman / 2012 Ducati Monster 796
    129 Post(s)
    Quote Originally Posted by dentinger View Post
    CLEAN / LUBE CHAIN. gas I don't remove. fill it up and add stabilizer. oil change before storage and then I ride it all summer with that oil. tighten up the bolts here and there. but maint is easy.
    May 2007
    Edmonton, AB
    12 Post(s)
    I just ran my bike empty, til it died.
    May 2007
    Edmonton, AB
    12 Post(s)
    The ducati will be a bit different. Battery tender, maybe fuel stabilizer, and I'll hopefully have at least a rear stand for it.
    Aug 2013
    14 Post(s)
    What is stabilizer? and what does it do??
    Quote Originally Posted by Daylindafung View Post
    Its to stabilize your fuel and protect your fuel system, including the tank from corrosion due to water build-up from condensation.
  11. The Following User Says Thank You to Flagrum_3 For This Useful Post:
    Daylindafung (08-07-2015)
  12. #11
    129 Post(s)
    yea I put mine on front and rear stands. deflate the tires to about half. put the battery tender on, and a little spray grease on parts that move. pegs and stuff. clean and regrease the chain.
    @Daylindafung but if you have any questions make sure to ask. theres a good 250 ninja following in the gta
  13. The Following User Says Thank You to Booter22 For This Useful Post:
  1. motorcycle mishap
    By roachkillah in forum Multimedia
    Last Post: 05-28-2015, 03:46 PM
  2. Motorcycle Sounds
    By 05Mazda3GT in forum Pictures and Videos
    Last Post: 04-17-2010, 01:46 AM
  3. New Hybrid Motorcycle
    By fourtrack78 in forum Other Cars
    Last Post: 03-21-2006, 04:34 PM
