Results 1 to 1 of 1
Thread: 2010 Mazda 3 sport rear bumper removal
    Newbie LiviuTincu's Avatar
    Nov 2010
    5 Post(s)
    Default 2010 Mazda 3 sport rear bumper removal
    This thread was done since I was working on replacing the rear reflectors (add LED on the reflector housing). So before having the LED installed, I had to remove the bumper. It was not difficult at all, except one screw that was rusted and I had to brake it. Here is how it goes:
    total of screws , nuts and clips to be removed are around 20, different sizes
    tools: sockets, knife and screwdrivers.
    bumper view and screws / nuts / clips location
    [IMG][/IMG]
    [IMG][/IMG]
    What I'm describing here is for one side (left) , you have to do the same for the other side.
    First, remove the rear tail light, each one is secured by three nuts #8, and one clip(no need to be removed), removed from inside of the trunk behind the cover/door.
    After you remove the nuts, pull firmly towards the back of the car to get it off from the clip in the corner of the light housing.
    Now you should see one bolt and one clip. Take the bolt off and leave the clip for last after you remove all other screws, this way the bumper wont fall off on your driveway and scratch. Also behind a round cover is one more bolt, take it off.
    Now go behind the rear wheel and check for one bolt and one plastic clip that hold the cover
    [IMG][/IMG]
    After you remove those, pull the cover to separate from the bumper, you will expose two more screws you need to remove
    [IMG][/IMG]
    After you have removed those, at the very bottom of the bumper is one screw with a square nut that holds the bumper with the cover together, if is rusted like mine was, you may need to cut it off or something
    [IMG][/IMG]
    Now go under the car and remove the last two bolts .
    [IMG][/IMG].
    Now pull the side of the bumper to separate it from the fender bracket.
    Now you can take the plastic clip off from the first step and you bumper should come off.
    Be careful for the plate light wires if they are still attached to the bumper.
    Happy ?
  2. The Following 3 Users Say Thank You to LiviuTincu For This Useful Post:
    Raxor (10-06-2015),RickD25 (05-22-2017),ryan2.3 (09-27-2015)
  1. 2014 Mazda 3 Bumper Removal
    By Hyperion in forum How-To Guides & Reference
    Last Post: 07-28-2014, 11:22 AM
  2. Installing Reflectors / Bumper Removal Video - 2010+
    By TheZProjekt in forum Lighting, Electrical & Security
    Last Post: 04-14-2013, 08:22 PM
  3. Rear Bumper Removal & Rally Armour
    By Fuyuzora in forum Exterior Styling & Appearance
    Last Post: 10-12-2011, 09:16 AM
  4. Anyone have DIY for rear bumper removal 2010 sport?
    By Twinbros in forum How-To Guides & Reference
    Last Post: 03-09-2010, 02:07 AM
