How do I go about removing my headliner my 3 has a sunroof?
I haven't taken one out on the 3, but I think it's about the same as on other Mazdas. Take our all the upper pillar trims. Remove sun visors, and interior lights. Pull out the trim around the sun roof. Remove any remaining trim clips. Pull the headliner down and out.
I'm pretty sure they do, as the headliner tucks in behind them (albeit only by 5mm or so). But to bring it down without folding it much the pillars need to be out of the way.
Although you need to be aware of the airbags, you can generally pull the trim out without doing anything special. However if you want to be extra safe, disconnect the battery and step on the brake pedal for 10s to drain any residual power in the system.
cwp_sedan (11-18-2015)
Aitch (11-18-2015)
@schmat66 might be able to give you some tips
My Parents bought me more Hot Wheels than Barbies when I was little...
Thank yous I'll try it out
headliners are pretty easy, aitch nailed it bang on, i removed my a pillars but only bent my b and c pillars back enough to get my headliner out, other then that trims/ weatherstrips/ lights/ etc. 15-20 mins and its out.
DAI | XXR | NANKANG | DOMINANT ENGINERING | KW | BRIDE
KAPTION | JVC | OPTIMA | INJEN | TRI POINT | NRG | AVENUE
STRIPPING TECHNOLOGIES | EXCLUSIVE WHEEL AND TIRE | KAPTION
I did mine today. I took pilars off to dye them blacka s well
Sunroof has 2 push tabs at the front that need to be slightly push to allow 1 st bypass of sliders. Then only 1 x-mas tree pin holding it in on the passenger side at the rear / sunroof slides out “ cloth part”
Proof
