Results 1 to 9 of 9
Thread: suspension
    Sep 2007
    Default suspension
    I had my car serviced yesterday, and installed new front struts/springs and mounts.
    Afterwards, an alignment was performed.
    Today, i have noticed that there is a knocking sound coming from the right front that is a new sound
    I am thinking it could either be
    1. improper torquing of lug nuts
    2. struts not fastened properly.
    3. other (your opinion or other option)
    If it is the struts not fastened, is the alignment affected by that?
    opinions?
    -g
    71 Post(s)
    Default Re: suspension
    I would suggest you take it back to the place that serviced your car. Start there as they did all of the work.
    It could be anything at this point but if the noise wasn't there before it is probably related to whatever was done yesterday.
  3. The Following User Says Thank You to cwp_sedan For This Useful Post:
    gramps (12-02-2015)
    2012 Porsche 911
    132 Post(s)
    3. Springs settling in? Had some sounds coming from suspension after I got new struts and springs. Was gone after a couple of weeks. Maybe?
  5. The Following User Says Thank You to Jackal For This Useful Post:
    gramps (12-02-2015)
  6. #4
    #DipItRealGood FD22's Avatar
    Jan 2012
    Etobicoke/Michigan
    E92 335i
    1007 Post(s)
    Quote Originally Posted by Jackal View Post
    Could be it. Could be the springs not seated properly either.
    But I'd definitely take this option first, before wasting your time and resources trying to diagnose it yourself.
  7. The Following User Says Thank You to FD22 For This Useful Post:
    gramps (12-02-2015)
  8. #5
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    250 Post(s)
    Depending on the sound, I would wager $5 that it's your sway bar end links. It's always those ****ers.
  9. The Following User Says Thank You to Hyperion For This Useful Post:
    gramps (12-02-2015)
  10. #6
    Sep 2007
    Thanks for the advice. I will do that. Though i am curious if the fix will affect the allignment
  11. #7
    71 Post(s)
    Quote Originally Posted by gramps View Post
    Ultimately if something is messed and they need to fix something that affects the alignment, I would expect them to do another alignment at no cost.
  12. #8
    97 Post(s)
    +1 Most definitely...If the issue is related.
  13. #9
    Newbie Gost's Avatar
    Aug 2017
    Maple
    Is the knocking noise only whenever you go over a bump? It's definitely sway bar links. If it's not too late, but at least you learn something...
  1. Suspension!
    By Fr!sco in forum Frequently Asked Questions
    Last Post: 04-01-2009, 01:04 PM
  2. Suspension
    By RNUOVR in forum Suspension & Brakes
    Last Post: 02-11-2009, 03:32 PM
  3. suspension?
    By lightingwhite32008.5 in forum Suspension & Brakes
    Last Post: 11-08-2008, 10:08 PM
  4. suspension
    By steviewoods in forum Suspension & Brakes
    Last Post: 07-13-2008, 02:15 AM
