Results 1 to 9 of 9
Thread: 2011 mazda 3 2.0 sedan, noise coming from rear passenger.
    Jan 2016
    hamilton
    7 Post(s)
    Default 2011 mazda 3 2.0 sedan, noise coming from rear passenger.
    Hello guys, I have 2011 mazda 3 sedan. 2.0. 85km on it, Ive been experiencing this noise coming from my rear passenger whenever i am accelerating at any speed. i cant describe the sound but seems like a plastic that got stuck or something. checked my rear seats and trunk might something be stuck on it like plastics, or any material but did not found anything.It doesn't affect anything in terms of handling and performance of my vehicle yet but its really annoying. Sound goes on and off. any1 have experience thesame issue as mine? let me knw thanks
    Member Cab0oze's Avatar
    Nov 2009
    Montreal :(
    18 Post(s)
    Default Re: 2011 mazda 3 2.0 sedan, noise coming from rear passenger.
    Noise coming from rear passenger when accelerating... hmm. Well Mazda3s are surprisingly quick, which can surprise passengers a bit! But if the passenger becomes too annoying just tell him/her to get out and walk. Should fix your problem.
    Canada gave us rust and DRL. Thanks for nothing Canada!
  3. The Following 2 Users Say Thank You to Cab0oze For This Useful Post:
    cwp_sedan (03-21-2016),Turbospeed_3 (03-22-2016)
    Newbie Turbospeed_3's Avatar
    Jun 2015
    20 Post(s)
    Try jacking up the back and pop the wheel off could be in the brakes doesnt hurt to take a look
    129 Post(s)
    Quote Originally Posted by mz3Danish View Post
    Is it a tapping type noise? or a rotational one?
    Costco = good cheap solution
    It's like a buck a nut
    Could it be your tire? When I switched to 18" wheels and tires there was a substantial noise coming at higher speeds.
    I get a knock knock , kinda rotational at low speed when going slow over bumps.
    I thought rear stabalizer endlinks maybe loose and undone and bar is tapping.
    Actually they needed replacing and put one a heavyduty set from whiteline
    but noise was back ...I think now its associated with the damper going up and down over bumps or speed bump.
    If its not that ... raccoons squirrels drunk and banging their heads together....
    Possible wheels bearing too.
    Have you checked the control arm ?
    Check your shock mounts and/or your trailing arm bushings.
  10. #9
    Mine was not a bearing..
    I found my problem and was fixed.
    new Front and rear endlinks were loose ... loctite and retighted
    No more knocking around...
  1. Replies: 14
    Last Post: 10-20-2014, 05:14 PM
  2. Ticking noise coming from rear/ passenger side of the motor???
    By davepolak in forum Problems with the Mazda3
    Last Post: 06-22-2012, 11:55 PM
  3. Strange whirring noise coming from passenger rear. Is it normal?
    By Kalel in forum Problems with the Mazda3
    Last Post: 04-18-2008, 11:12 PM
  4. Squealing noise coming rear while driving (Not during braking)
    By Gods Son in forum Problems with the Mazda3
    Last Post: 11-20-2007, 09:40 AM
