Hey all,
Has anyone replaced the plugs in the 3 Sky with aftermarket? I can't justify spending $42 per plug on the OE parts. I got a set of NGK that apparently work with the sky, but the ceramic of the plug is too big for the boot. It's way too tight in there.
Anyone have any luck with aftermarket numbers? I've searched online and haven't found anything concrete other then NGK 4344 - read rumors about theses working, but the nut size is larger then that of the stock plugs.
