Results 1 to 25 of 26
Thread: about to hit 100K
    Jun 2012
    Default about to hit 100K
    Hey guys,
    need some help.
    my 12 speed is about to hit a 100k. which means no more warranty.
    While putting my summers on last week I noticed my pads and rotors need to be replaced. ( any advice where to buy the parts from and which brand would you suggest)
    as well now I am going to do my own oil changes. which synthetic engine oil do the most of you use on this fourm?
    Thanks Anthony
    Default Re: about to hit 100K
    Quote Originally Posted by delson85 View Post
    Hey guys
    Thanks Anthony
    Rotella T6
    Jr Member DLYDRVN's Avatar
    May 2013
    Toronto/Kitchener
    2009 Speed3, Yoz. Mazda2
    110 Post(s)
    Rotella T6 is the oil almsot everyone uses. Gives good results in UOAs. I've switched to Liqui-Moly 10w40 and my UOA's have gotten significantly better. But it is much more expensive, and the T6 is proven for this platform. It's the easy and safe choice for our engines.
    Performance COBB AP v3 (345whp/360wtq) - CS Puppy Power Turbo - HTP 3" Widepath - Turbosmart BPV - CS TMIC - Cobb 3-Port - Teflon TIG - CS Catch Can - Autotech Internals - UR 3" Turboback Exhaust - ACT 6-Puck Ceramic Clutch Kit - Filled TMM - CPe RMM - JBR Short shifter - CS Short Shift Plate - Shifter Bushings - CS Front Big Brake Callipers - StopTech Sport 309 Pads - CS FSB - CS RSB - Bilstein B14 PSS Coilovers - CS Mid-Brace - Defi Gauges - CS Steering Wheel - FAST Underground 18x8 - BFG gForce Sport comp2 235/45r18
    Sound & Appearance Kenwood eXcelon DNX893s - JL C3-570 - JL 10W6v2 sub - JL XD400/4 - JL XD600/1 - Kinetik 600 Power Cell - 2AWG Big 3 - Redline Boots - CS LED Fogs - CS Lic. Plate Kit
    May 2013
    Toronto/Kitchener
    110 Post(s)
    As far as rotors go, StopTech, Centric, OEM, and EBC are all good bets. As far as pads... there are probably as many opinions as there are owners. The general consensus is that for street, it's hard to beat OEM. Compound is made by Ferrodo IIRC, and it's got great initial bite, good emergency stopping power, but will fade with high heat. If you want a better modulating pad for street and auto-x use, Hawk HPS are a good all around reviewed pad, and Corksport pads also get good reviews. For any street use, avoid track oriented pads. They need heat to work well, which means on the street, when you need them in a panic stop, they will fall on their face and you will end up in someone's trunk.
    Oct 2009
    2012 Volvo C30 T5
    14 Post(s)
    Pads: Stoptech 309 for amazing DD capabilities while being able to handle autocross and lapping day duties. They only squeak when literally smoking hot, and have excellent bite even in the winter. Been using them for DD, track, autocross on my C30 since 2013, on both N/A 3 and speed 3 calipers.
    Only downside is they're dusty.
    Never stop zoom-zooming
    Jun 2012
    thanks for all the advice.
    novice question.
    if I put Rotella T6 on this oil change. can I switch to any other 5w-30 full synthetic after?
    rotella T6 is on sale at part source.
    Jr Member Cjcoolen's Avatar
    Feb 2016
    Toronto, ON
    7 Post(s)
    Why would you want to?
    Jun 2012
    lol hence a novice question.
    so it is not recommended?
    May 2013
    Toronto/Kitchener
    110 Post(s)
    There is no technical reason you can't, i think he is simply suggesting that it's still one of the best and most easily available oils for our platform. It does go on sale regularly and if you're a CAA member you get a discount at Napa on all oils (T6 included), so really its worth running all the time.
    If money is a serious concern, think about the cost of a new engine versus a few extra bucks for the oil 4 or 5 times a year. Our engines are extremely hard on oil and it's not the place to cheap out TBH. You really only need to buy a single 5L each change and use the partial jug from the first fill for the extra 500ml or so needed, so the added cost is negligible.
    Jun 2012
    Quote Originally Posted by DLYDRVN View Post
    that was good insight.
    thanks
    Newbie nigvlb_'s Avatar
    Sep 2015
    1992 Mazda Miata
    Rotella T6 5w-40 OR Penzoil Platinum 5w-40.
    Use either and never look back.
    Liquid Silver Metallic 2013 Mazdaspeed3 || BNR S4 Turbo || Fully Bolted & Freektuned
    Jr Member KidRambo's Avatar
    14 Post(s)
    I had no idea CAA had that. What's the discount like @DLYDRVN ?
    Jun 2012
    so I went to part source and they were saying T6 doesn't comply with the fuel spec for a speed 3. which should say API-ILSAC.
    any info on this guys?
    Plus he said the T6 should be for desil engine only.
    any help would be grateful?
    Feb 2016
    Toronto, ON
    7 Post(s)
    It is supposed to be for diesel..
    But dude, mazdaspeedforum explains why our cars can use that oil and is recommended for the speed platform.
    Does your part source customer rep drive a speed3 or a speed6?
    May 2013
    Toronto/Kitchener
    110 Post(s)
    Quote Originally Posted by KidRambo View Post
    10%. Not too bad but it includes tools and everything else. Better than a kick in the head!
  16. The Following User Says Thank You to DLYDRVN For This Useful Post:
    KidRambo (05-13-2016)
  17. #16
    Jun 2012
    Quote Originally Posted by Cjcoolen View Post
    thanks cjcoolen. I told the guy the forum recommends that. but he was making comments about hurting the engine. so I wanted to confirm with you guys first.
    much appreciated
    thanks
  18. #17
    May 2013
    Toronto/Kitchener
    110 Post(s)
    much appreciated
    thanks
    One thing thats always worth noting is that most parts source guys know about as much about a DI engine as they do a Rotary, if they know anything that isn't straight up heavy and american.
    Also many of those and dealers included more or less _have_ to quote the book at you for liability reasons.
    What they claim is gospel truth and what is real world applicable are often quite different.
  19. #18
    Feb 2016
    Toronto, ON
    7 Post(s)
    I asked for an intake valve cleaning on my speed3, and advisor told me to get the fuel injector flush... the speech about it was so promising that if i didnt know any better, i would have done the flush. I kept saying that it was a direct injection but advisor still said that my fuel cleans my intake valves.
  20. #19
    Newbie Jonathan13's Avatar
    Oct 2012
    Stoney Creek
    novice question.
    Even cheaper at TSC, sale starts today
    Sent from my SM-G900W8 using Tapatalk
    2007 Mazdaspeed 3 CWP
  21. #20
    Sep 2015
    1992 Mazda Miata
    LOL.
  22. #21
    Jun 2012
    is it common for our MS3 to be burning oil?
    what should I do to fix this?
    when I did my last 2 oil changes I noticed I have only gotten back about 2.5-3L of dirty oil. from talking to people they are saying it should only burn about 1L (from one oil change to another) any more might be something to look into.
    around my exhaust tips it is black. but that has been there since day one.
    would love to hear your guys advise
    Anthony
  23. #22
    295 Post(s)
    Shouldn't burn any oil...It's usually turbo, rings or PCV issues.
    - 2021 Porsche Macan GTS -
  24. #23
    Jun 2011
    Ottawa
    You would know if you have an issue. When you go max throttle, is there black smoke behind you?
    -- Black Mica Mazdaspeed 3 --
    STOCK FTW ... well because warranty
  25. #24
    Professor
    Jul 2013
    1992 FD3S
    89 Post(s)
    Quote Originally Posted by captobvious75 View Post
    Black smoke is fuel.
    Blue smoke is oil.
    -Geoff
  26. #25
    Jun 2012
    im going to bring this back up
    my car is about to HIT the 135K mark.
    any suggestions to what maintenance i should do?
    looking at the manual and care. other that the regular oil change it is requesting spark plugs.
    any suggestions?
  1. Unreleased Drake OVO Shoes 100k???
    By rick@garage16.ca in forum General Lounge
    Last Post: 01-18-2014, 05:20 PM
  2. 07 Mazda3 Sport GT - 100K - yes/no/maybe
    By CJay in forum Buying a Mazda3
    Last Post: 03-14-2011, 01:39 PM
  3. 100k KM inspection needed ?
    By Battl3hamm3r in forum Mazda3 General Discussion
    Last Post: 08-25-2009, 07:34 PM
  4. Dream job 100K in 6 months...any takers?
    By towelsnap in forum General Lounge
    Last Post: 01-15-2009, 01:18 AM
  5. banging noise coming driving over 100k
    By bbc20000 in forum Problems with the Mazda3
    Last Post: 09-10-2008, 11:13 PM
