Results 1 to 12 of 12
Thread: Rx8 swap?
    May 2016
    Default Rx8 swap?
    Hey, I was wondering if anyone here knew if it would be possible to swap a Mazda speed 3 engine into an rx8, and keep it rwd? Would the transmission still be able to line up?
    Sent from my Nexus 5 using Tapatalk
    Moderator loki's Avatar
    881 Post(s)
    Default Re: Rx8 swap?
    vs making the RX8 front wheel drive?
    Orillia
    That would be a mess from an electrical and welding standpoint just to get 260 whp. There are kits of LS swaps into rx8s which would be easier and much better.
    Oct 2012
    Durham
    Anything is possible, but there is a reason everybody puts an LS into them.
    Sr Member The Wolf's Avatar
    Aug 2010
    Slaughterloo
    Peugeot SS
    69 Post(s)
    Surprised to see very few f20 swaps. High revving, similar power, but reliable.
    NO CREW
    Sr Member dentinger's Avatar
    May 2007
    Edmonton, AB
    12 Post(s)
    You'd probably need some sort of adaptor plate made up, to make the ms3 engine line up with the rx8 transmission.
    Then custom motor mounts, swap over the ms3 wiring harness, pcm, etc etc.
    Swap a LSx engine instead.
    Sent from my SM-G920W8 using Tapatalk
    I guess I should also rename the Engine/Drivetrain section "Arts & Crafts"
    2007 Mazda3 gx
    2003 Volkswagen GTI 20th Anniversary Edition
    2010 Kawasaki Ninja 250R
    2011 Dodge Ram 1500 Outdoorsman / 2012 Ducati Monster 796
    Jr Member MS3_'s Avatar
    Nov 2014
    37 Post(s)
    too much work, not worth it but props if you really wanna do it.
    like everyone said, do LS swap, much common but imo, i wouldnt do a V8 swap, keep it jdm as fck lol
    F20C, 2JZ, or RB26.
    マーズダビード
    Newbie nigvlb_'s Avatar
    Sep 2015
    1992 Mazda Miata
    Do a EJ207 swap
    Liquid Silver Metallic 2013 Mazdaspeed3 || BNR S4 Turbo || Fully Bolted & Freektuned
    Mar 2008
    79 Post(s)
    It's possible as many have said. Adapter plates are your friend.
    If you want to do it, and have the juice (cash) give er tits.
    Newbie jwoods_24's Avatar
    Jul 2011
    Hespeler
    LSx. Otherwise it's a lot of dough for "MS3 DISI!!!" exclusivity..
    Nov 2015
    Yes you can swap it, you will need an NC front subframe, NC engine block mounts, NC transmission, Custom PPF, Mazda3 Dash harness,Ecu,Key,Cluster, NC miata steering rack
    Nov 2015
    But realistically you would want to do a 2.5 and turbo that, the HPFP on the Disi motor will be in the firewall
  1. What would it take to swap the 2.5l into a gen 1?
    By a_ahmed in forum Engine & Drivetrain
    Last Post: 11-08-2017, 12:54 PM
  2. Emission help 2.5 swap into 06
    Last Post: 11-05-2015, 09:02 PM
  3. 2.3L - 2.5L swap
    By 74sickness in forum Mazda3 General Discussion
    Last Post: 06-13-2015, 12:34 AM
  4. Speed 3 front brake swap, Mazda 5 back brake swap, questions!
    By MattisBrown in forum Suspension & Brakes
    Last Post: 07-18-2013, 01:24 PM
  5. Hub Swap?
    By The Wolf in forum Wheels & Tires
    Last Post: 08-14-2012, 11:16 AM
