Results 1 to 11 of 11
Thread: Hemlor's logs
    Newbie hemlor's Avatar
    Aug 2008
    Default Hemlor's logs
    Hope everyone is having a good start to 2017.
    I'm wondering if you guys can take a look at the attached logs. The combined 3rd and 4th gear log is from Dec 2016 and the separate 3rd and 4th gear logs are from Jan 18/17 (earlier tonight). The mods are the same in Dec and Jan but I was still on summer tires in Dec while I'm now on winters (not sure if it matters).
    The main difference that I see is the wastegate duty is quite a bit higher in my Jan run vs. Dec but the other values seem within the range that Stratified lists with their flash updates.
    I appreciated any information you can share.
    Thanks a lot
    Below are a list of mods:
    COBB AP v2
    CPe Nano SRI
    metal TIP (unknown brand)
    JBR 88A RMM
    UR test pipe
    autotech HPFP internals
    CPe TMIC
    Denso 1-step colder plugs
    current map: Stratified flash tune Stage 3 93 v3.00
    Attached Files Attached Files
    Aug 2008
    Default Re: Hemlor's logs
    Forgot to mention that I have a gen2.
    287 Post(s)
    3000-6700 pulls please, not these high rpm ones...looks generally weak for the listed mods, get a pro tune.
    Aug 2008
    Thanks for your help.
    Would a pro tune help with power gains or with power delivery, or both compared to a flash tune?
    Jr Member MS3_'s Avatar
    Nov 2014
    37 Post(s)
    yup, what he said.. do 3000-6700 log and yes pro tune or even E-tune will be much better. get the stratified e tune, worth the money. i started with flash tune and now im etuned by stratified.
    マーズダビード
    Aug 2008
    Quote Originally Posted by MS3_ View Post
    Thanks a lot.
    I'll probably contact stratified in the spring for a custom tune.
  7. The Following User Says Thank You to hemlor For This Useful Post:
    MS3_ (01-19-2017)
    287 Post(s)
    Quote Originally Posted by hemlor View Post
    Both...makes a big difference running a tune for the car versus an OTS map.
    391 Post(s)
    @Fobio
    Sent from my SM-G935W8 using Tapatalk
  10. #9
    Aug 2008
    Thanks for the feedback. I've attached some logs that are in the recommended RPM range. I couldn't hit 6600rpm in the 4th gear pull, I got to about 5700.
    Regardless, I'll be getting a custom tune come spring or earlier.
    Thanks again
  11. #10
    May 2012
    52 Post(s)
    I would personally get a Protune to control the boost ramp up, you are hitting a high load (more than I would be comfortable with on stock pistons/rings) at a low RPM range.
    The OTS tune is pretty good compared to the Cobb OTS ones, but if you plan to keep the car for a while I would get a tune to keep the high calculated load out of the 3000-3500 range.
    @SomeGuy what do you think?
  12. #11
    287 Post(s)
    Yeah...among a few other things. Needs some MAF cal, LEC or BEC is too aggressive, has some flow issues above 5500rpm should be able to get a bit more out of a k04 in that rpm range.
  1. Pwdunmore's MS6 Logs
    By pwdunmore in forum MazdaSpeed3 Tuning
    Last Post: 12-06-2017, 01:47 PM
  2. My Logs
    By Booostin in forum MazdaSpeed3 Tuning
    Last Post: 10-17-2012, 02:16 PM
  3. 2zoom Logs's
    By 2zoom in forum MazdaSpeed3 Tuning
    Last Post: 06-08-2012, 08:29 PM
  4. caq's logs
    By caquricon in forum MazdaSpeed3 Tuning
    Last Post: 10-18-2011, 01:44 PM
  5. Some DH logs
    By TriniFyah7 in forum MazdaSpeed3 Tuning
    Last Post: 10-14-2011, 02:22 PM
