Results 1 to 17 of 17
Thread: Both HID lights stopped working.
    Jr Member Hotsky's Avatar
    Oct 2012
    Hamilton
    7 Post(s)
    Default Both HID lights stopped working.
    So today I noticed both of my HID lights stopped working at the same time. Which never happened before! I've installed the kit a couple years ago and hadn't had much issues other than lately passenger side would not come on sometimes so I figured capacitor is going bad. But both not working at same time all of a sudden? Chances of both bulbs or capacitors going together are pretty slim. So what could it be??
    Newbie ken6214's Avatar
    May 2013
    Pickering
    13 Post(s)
    Default Re: Both HID lights stopped working.
    I noticed when my battery was getting old, on a cold start they wouldn't always "fire". But simply turning them off and on again with the car running fixed it. Could this be it or are they not coming on at all??
    Oct 2012
    Hamilton
    7 Post(s)
    Battery should still be OK. It's a Costco one 3 years old now. I did a few short runs yesterday and had to start the car a few times and they weren't coming on.
    Note. I do have led strip light over each headlamp that I taped into slot where original halogen lights would go and they are still working!!
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    252 Post(s)
    I mean, an LED strip has nothing to do with your HID bulbs. What brand are your HID bulbs?
    Also three years from an after-market get seems about right. Also, what year is your car? I'm assuming it's not oem hid.
    Oct 2012
    Hamilton
    7 Post(s)
    Can't even remember the make of the Hid and yes they are aftermarket kits. Both sides going at same time is very unlikely IMO so I doubt they just died due to old age lol
    Car is a 2005 3
    84 Post(s)
    Relay harness
    Fuse
    Bad ground
    Hyperion's Avatar
    252 Post(s)
    What he said
    2012 Porsche 911
    133 Post(s)
    Core ocean.
    Oct 2012
    Hamilton
    7 Post(s)
    Quote Originally Posted by Default User View Post
    Relay harness
    Fuse
    Bad ground
    I'm not using a relay, just capacitors so no ground. I haven't checked the fuse, but the LED strip I mentioned in tapped directly into where the OEM halogen light would be and its the its still working.
    Hyperion's Avatar
    252 Post(s)
    You don't need capacitors on a mazda 3 to my knowledge. One I installed today worked fine without, just a relay
    Uncle Ben
    Sep 2005
    capacitors were used to stabilize the 12v from pulse to constant. This way people used the HID kit as DRL's/low beams rather than bypassing them completely
    Aftermarket HID kits can last 1 day or a few years. The quality has really come down on them. I wouldn't be surprised if both died. However, I would check the power supply to the capacitor before jumping to conclusions. Also, some capacitor kits did utilize a relay kit. I did recently have a car where the relay was clicking and functioning however no light output. The relay was fried.
    Hyperion's Avatar
    252 Post(s)
    Quote Originally Posted by McGuyver_3 View Post
    As soon as I saw you replied I remembered that some used the hid as drl's too.
    Oct 2012
    Hamilton
    7 Post(s)
    Yes I don't use a relay just the capacitors to eliminate the flicker issue in daytime mode.
    Hyperion's Avatar
    252 Post(s)
    The best way to troubleshoot this, is to use a voltmeter and start at your OEM connections and test the voltage. If it full to there, then you know you have power. So then it's either the ballast or the ball. Alternatively, if you still have your OEM bulbs, you can just plug those in and see if they turn on.
    84 Post(s)
    Have you tried disconnecting the HIDS and using just bulbs?
    Oct 2012
    Hamilton
    7 Post(s)
    Tested halogen bulb and it works fine. So must be either the ballasts or HID light bulbs. I have a spare set of lights somewhere I'll test then I find them but I have my money on the ballasts.
    PS did some digging around and they are Vvme brand and i had them running for 3 full years now. I guess not bad.
    2012 Porsche 911
    133 Post(s)
    Isn't it time to just buy a new set and install? They really only last a maximum of 3 years in general and maybe these are just done. Better alternative than buying a capacitor here and a relay there only to have something else go.
  1. Fog Lights Stopped Working
    By goodcase in forum Electrical
    Last Post: 07-30-2013, 06:09 PM
  2. My Fogs stopped working help!
    By Acradian9 in forum Lighting, Electrical & Security
    Last Post: 03-27-2010, 10:17 AM
  3. HORN stopped working
    By matt9 in forum Lighting, Electrical & Security
    Last Post: 04-11-2009, 07:12 PM
  4. Angel Eye(s) Stopped Working...
    By RedRaptor in forum Lighting, Electrical & Security
    Last Post: 04-11-2009, 12:15 AM
  5. Fog lights STOPPED working?
    By sp3GT in forum Lighting, Electrical & Security
    Last Post: 06-19-2008, 06:59 PM
