Results 1 to 13 of 13
Thread: New impact not taking of lugs.
    Nov 2016
    Default New impact not taking of lugs.
    Hopefully this is a valid place to make this post. Bought a air impact capable of 230 or 250lbs, 20 gallon tank running at 115psi, and what I think is a 1/2 hose, say 25ft. Can't take a single lug nut off. ( Not my car, winter rims, no idea how long the nuts have been on ). It can tighten a lug and then not take it off. (Didn't overtighten, was just for testing). I don't get it. There's gotta be something I'm missing.
    Why won't it take off lugs?
    Ontario
    Default Re: New impact not taking of lugs.
    Have you oiled the tool? Oiling can affect torque output significantly. Make sure it's 'air tool oil'. Also, a lot of impact drivers have knobs on them for torque output, make sure it's turned to the highest number. Mine is the princess auto one below and the knob has to be at 4 for some serious spinning. Because of how the hammer mechanisms are designed in impact guns, they can bias towards more torque in F vs R. You should be able to crack them no problem though.
    Nov 2016
    Quote Originally Posted by morganc View Post
    On the highest setting yes. Oiled, not yet. Was the first use. I will oil it before my next use for sure. But I feel like there has to be something else. Oil can't be everything I'm doing wrong.
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    250 Post(s)
    Air impact usually only have one setting for loosening and that's maximum. For tightening they sometimes have three or four settings. But honestly, for taking off and wheels, in order to not damage them I would loosen them with a breaker bar. When you use an impact any finish that's on the lug nuts often comes off, as well as the paint on the inside of the holes on the Wheel.
    Nov 2016
    Interesting to know, can't say I've ever seen a shop use a bar before a impact. How much does a breaker bar typically cost?
    Hyperion's Avatar
    250 Post(s)
    Like 30 on sale.
    A shop cares about time, and money. Not your lugs
    389 Post(s)
    Or you can buy something like this - https://www.amazon.ca/Protective-Whe.../dp/B00H8G353S
    Nov 2016
    Well, wouldn't fix my problem though. But neat.
    Uncle Ben
    Sep 2005
    37 Post(s)
    When installing lugs at a shop, we use torque sticks on the gun to prevent over torque.
    In your case the 115 psi may not be what your issue is. There is another rating on the compressor that you require. If I remember correctly its called CFM. The higher the number the better. However if you bought a cheap impact, then that could also be an issue. I have an 1100FT/lbs impact which does almost everything on my shop compressor. On my home compressor, it works until the compressor kicks on. I am only using an 8gallon. I use very thin hose as well.
    1991 Nissan Pathfinder SE-V6 Red/red interior - trade in
    2005 Mazda 3 GX ty grey/black interior - Write off
    2010 Mazda 3 GT E sedan Crystal White Pearl/on black interior- trade in
    2010 Speed 3 Crystal White Pearl/on black interior all options- current
    2007 Mazda 3 GS silver- current winter ride
    2002 BMW 330ci silver- new toy
    Nov 2016
    I think it might be the impact to be honest, cheap dealership cheapingbojt where they can. Its a 22gallon compressor with a max of 115psi,
    Ontario
    I run a 20 Gallon at about 130psi and it will turn the toughest of bolts. It's probably the impact.
    19 Post(s)
    THIS
    Cheap crap tools = hours of frustration
    Sr Member Reddie1337's Avatar
    Feb 2012
    Oakville, Cambridge
    2001 Chevy Cavalier Z24
    256 Post(s)
    THIS
    I use a mastercraft impact for day to day things, and have a really good 20v at work, and the mastercraft one, which I got in an air kit from Crappy Tire for $80 total works great. Some cheap stuff can be really good. Works better than a co-workers Mac Tools gun most days.
    Sent from my iPad using Tapatalk
    Mods to Date:
  1. Anyone taking/taken the GMAT?
    By lprince in forum General Lounge
    Last Post: 11-18-2011, 01:45 PM
  2. No impact gun for aftermarket lugs?
    By shu5892001 in forum Wheels & Tires
    Last Post: 02-24-2011, 10:16 PM
  3. Impact Wrench
    By eman124 in forum Mazda3 General Discussion
    Last Post: 06-13-2008, 01:41 PM
  4. Help choosing an air impact gun
    By WeatherB in forum Engine & Drivetrain
    Last Post: 02-08-2008, 10:00 PM
  5. Taking it to the track
    By ///M in forum Mazda3 General Discussion
    Last Post: 11-11-2004, 01:32 PM
