Results 1 to 12 of 12
Thread: some RUST in my car. PLEASE HELP :(
    Noob JeremyB's Avatar
    Jul 2016
    Default some RUST in my car. PLEASE HELP :(
    got some RUST in my car. what should i do?
    QUESTION; Should i repaint the rusty part to cover up? or any Mechanic shop that can do something about it?
    PLEASE HELP
    Thanks in advance guys
    Feb 2017
    Guelph
    Default Re: some RUST in my car. PLEASE HELP :(
    You have rust Inside your car?? I'm assuming you mean outside, your best bet is to sand down the rusty spot, use a primer and a paint to cover it up, but this will only temporarily fix it. Rust on a Mazda?? I don't believe it, You must be the first one to ever get rust
  3. The Following User Says Thank You to 2012mazda3hatch For This Useful Post:
    p-o-g-i (04-27-2017)
    Post some photo's.
    Moderator Mr Wilson's Avatar
    Jan 2010
    227 Post(s)
    ^^^Agreed, photos would help.
    0.000212524463 gigawatts
    Apr 2015
    is it worth fixing??
    why not just save the money, let it rust, and just buy another car?
    Jul 2016
    Post some photo's.
    Car has hit or been hit, therefore paint has been removed and the metal is now rusting. Looks fixable if you take it to a good body shop. Going to cost some money likely $700-$1000 at least.
    Newbie YepYep's Avatar
    Apr 2010
    Quote Originally Posted by 2012mazda3hatch View Post
    NO rust on a Mazda!? I don't believe it. We need to agree the metal quality of Japanese car is not as good as the German cars (ABB). There must be some (or too many) rust on a 10 years old Japanese car, here or there...
    Check your underneath, I don't believe there is no rust. And after some more years, you will find rust on the fenders something...
    And while you see the rust showed up over the outer paint, actually it's very serious already. Maybe it's already penetrated from inside out thoroughly. Regarding OP's car, I agreed to S.F.W, it will be costly to fix it. And I can tell another bad news, the door panel rusty spot and the quarter panels are not that thick, maybe after sanding down the rust, it will not be too much metal remained... Maybe actually the shop will need to cut the rusted piece out and give your car a patch to weld on the remained sheet metal to fix it.
    And even you can find a good body shop and pay the good money for a good restoring job, it won't last for a good time and will rust again.
    To my opinion, just cheap done DIY, 10 bucks to get an aerosol can of some kind of Rust-Check primer some thing, sand the rust out (no need to remove it completely, it's not worth a detailed job which will cause you a long time to finish), and use the spray can to cover the rust. And keep doing it from time to time to slow down the rusting speed. AND begin to look for your next car.
    The rust will not affect your car's performance and you still have years of time before the rust can finally damage your car's safety. It's just making your car not looking good any more.... This maybe a "good" news to give you some comfort?!
  10. The Following User Says Thank You to YepYep For This Useful Post:
    JeremyB (04-19-2017)
  11. #9
    @JeremyB -Those spots are nothing. If you have a friend who can help or do it yourself, you can fix those areas up easy and in no time. Cost will be minimal, just materials such as sandpaper, body repair kit and paint.
    If done correctly it'll last several years yet.
  12. The Following User Says Thank You to Flagrum_3 For This Useful Post:
  13. #10
    Jul 2016
    I guest ill try to fix it by my self. Any product(s) that i can used to fix it such as spray, or what so ever? I really apreciated your help
  14. #11
    Orillia
    Fix it yourself if you're up to it. Seeing as it is a first gen you probably only plan to own it for another 4 years. That amount on your car isn't embarrassingly bad.
  15. #12
    Quote Originally Posted by JeremyB View Post
    You'll need a drill to make it easy. Grind down the rust to metal using a wire brush attachment. A body repair kit can be purchased at CT and includes fiberglass, bodyfilla, sandpaper etc. Then some primer paint, fine sandpaper and tape, and finally paint and clear coat. As for paint you can just try to match it as close as possible through purchasing it basically anywhere in aerosol cans, or there are some places you can take your colour code and they will match the colour exactly, and also available in aerosol. I can't remember any names of places which do so, but maybe someone else can chime in on that.
    Oh and best to take your rear bumper completely off when repairing those quarter panels.
  1. Rust, Rear Door, Well, Tail light - Tips to slow down the rust
    By lcianf01 in forum Problems with the Mazda3
    Last Post: 05-31-2015, 01:05 AM
  2. Rust on my mazda 3 - rust proof every year with krown
    By phoenix_bladen in forum Mazda3 General Discussion
    Last Post: 04-12-2012, 03:31 PM
  3. Does Not rust proofing your car with mazda void Rust warrant?
    By Donshaw in forum Exterior Styling & Appearance
    Last Post: 09-14-2011, 04:04 PM
  4. Will rust proof from Krown void my dealer rust proofing warranty?
    By fuhreakz in forum Exterior & Interior Maintenance
    Last Post: 08-30-2010, 10:26 AM
