Results 1 to 9 of 9
Thread: How long should brakes last?
    Nov 2013
    Ottawa/Gatineau
    Default How long should brakes last?
    My oem brakes on my 2007 GT lasted until 90 000km and I then installed aftermarket pads and rotors which were noisy so I decided to replace all 4 corners with OEM pads and rotors. That was in October 2014, now my car has a really bad vibration when braking from 90-100km/h. I think they should of lasted longer than that without warping? I am thinking maybe the local guy who installed the winter tires with his air impact warped the rotors last fall? I know at my last oil change at the mazda dealer, they told me that my right rear parking brake cable and caliper are starting to seize, maybe that could be it? If the vibration is coming from the brake pedal, how can I tell if it's the front or rear brakes that's causing it or if it's all four of them?
    Noob Galaxy771's Avatar
    Mar 2017
    Ottawa
    Default Re: How long should brake last?
    I honestly doubt your mechanic warped your rotors when he impacted the wheels on. Get a brake service done or maybe take your brakes off and get some sort of lube or even anti seize on the side of the pads where they mate with the caliper and maybe a bit for the rotor where it attaches to the hub and see if that helps. As for the vibrations, check brake fluid level and see if your parking brake cable is seized. It could cause the pads to slightly be engaged to the rotor. Brake pad thickness can effect how you brake as well so make sure the pads are still in good shape.
    Another thing to note is that your rotors don't have a "won't warp by this time" rating. Even hitting a bump wrong can warp your rotor or they can stay straight as an arrow forever.
    Modifications: Mazdaspeed3 rear sway bar, AWR rear motor mount, Raceland coils, Konig Illusion 18x8 wheels with +45 offset, Corksport cat-back exhaust with Vibrant 4-2-1 header, Corksport short ram intake, Stage 3 clutch, Angel eyes with HIDs, Mazdaspeed3 interior swap with LED interior bulbs, Mazdaspeed3 spoiler and sideskirts and drilled/slotted rotors
    Boosted soon
    Orillia
    The causes or your brakes warping are either you installed very cheap rotors or you brake very aggressively and frequently. Hopefully the OEM rotors I assume Mazda installed were genuine OEM. I have an 07 gt with 210 000km on it and the factory rear brakes....but mine is a highway driven manual trans.
    Nov 2013
    Ottawa/Gatineau
    Quote Originally Posted by jeff7670 View Post
    All mazda parts, rotors and pads and not the mazda value line that the dealer sells for cheaper, the good quality stuff. I dont drive aggressively or frequently but I hears that not torquing the wheels properly can contribute to this. I still take everything apart and have a look.
    Jr Member js593's Avatar
    Jan 2012
    Winnipeg MB
    You say you get vibrations at 90-100kph, is that when braking at that speed? Sounds like you have either bad tires, or something suspension is done.
    Sent from my SM-G930W8 using Tapatalk
    ____________________________________
    2011 Celestial Mica Blue Mazda 3 GS Sport
    2.5L 6 Speed Manual
    DC Sports Intake, 5.5K Morimoto Retrofit HID kit, Sure Motorsports RMM
    Enkei Wheels,R40 lug nuts, ISC N1 coilovers, Corksport short shifter, CS Rear sway bar
    Ebay front strut bar, Custom magnaflow axleback w/ 4" tips, Style M front lip
    Mar 2017
    Ottawa
    I originally thought it might be a bad alignment but if it only happens when he brakes then it's possibly a wheel bearing I would think. Assuming it has nothing to do with the brakes that is.
    Member bunchi's Avatar
    Dec 2007
    Markham, ON
    Vibrations while braking will be the rotors. If you hear a noise, sort of like a humming sound from the wheels when the car is moving, it's a symptom of bad wheel bearing. It gets louder as you go faster.
    Beauty is in the eyes of the beer holder
    Feb 2013
    5 Post(s)
    Default Re: How long should brakes last?
    Did you break-in the new pads properly?
    Brake warping is a myth, it's simply not true in 99.9999 (and many more 9s)% of cases.
    What is most likely actually the cause is uneven pad material transfer (deposition) between the pads and the discs, resulting in thickness variation, or run-out. This very small difference in the layer of pad material (not visible to the eye) on the disc is what is causing brake vibration.
    The most effective way to avoid this is to strictly follow the pads' break-in procedure.
    Nov 2013
    Ottawa/Gatineau
    Quote Originally Posted by WHO View Post
    So I am trying to fix this issue before winter, the bedding procedure I followed once the brakes were installed was this one:
    https://www.powerstop.com/brake-pad-break-in-procedure/
    I see that the rotors that Mazda sell are not a coated rotor, I wonder if the aftermarket Wagner or Raybestos coated rotors would be better since they would withstand rust at the hub and inside the actual disk?
  1. How long can oil jug last?
    By Stretch in forum Mazda3 General Discussion
    Last Post: 01-09-2013, 06:49 PM
  2. Wow.... what a long day!
    By RECREATIONAL_ANXIETY in forum Mazda3 General Discussion
    Last Post: 06-14-2010, 08:14 PM
  3. How Long does it take to get a new Car?
    By actionjax in forum Mazda3 General Discussion
    Last Post: 03-29-2010, 06:39 PM
  4. How long do OEM brakes last?
    By Malcolm991 in forum Suspension & Brakes
    Last Post: 05-06-2009, 08:36 AM
  5. How long do OEM brakes last?
    By Malcolm991 in forum Mazda3 General Discussion
    Last Post: 03-04-2009, 11:43 AM
