Results 1 to 5 of 5
Thread: Rear break pads/rotor replacement
    Newbie YuukiPunkyHeart's Avatar
    Dec 2015
    Toronto , Ontario
    Default Rear break pads/rotor replacement
    So i went to active green and ross for wheel balancing and i asked them to check my breaks coz sometimes I have to hit my brake hard before i can makr a full stop. They said i need to replace my rear brakes. Now thing is i dont know which one to get. From them itll cost $400 ish with labor but im not sure if itll be the same as OEM quality. Any suggestions?
    Sent from my LG-H915 using Tapatalk
    Newbie Teh_baje's Avatar
    Nov 2015
    Default Re: Rear break pads/rotor replacement
    OEM rotors should be around $200 maybe a bit less or a bit more. I bought front and rears for my gen 2 speed 3 for $420 last year and my rotors are bigger. Granted I put them in myself so labour was free. Honestly I would buy OEM and take it to them for install.
    Noob ZimZamTheFlimFlam's Avatar
    Nov 2016
    Quote Originally Posted by YuukiPunkyHeart View Post
    Look on Amazon for Max advance brakes. Super cheap and great performance. I have a set of drilled and slotted rotors and ceramic pads waiting to be installed. All 4 rotors and 8 pads on cost me 187$ after everything.
    Sent from my ONE A2005 using Tapatalk
    Dec 2015
    Toronto , Ontario
    Maybe mine would be a bit more expensive. I have a 2015 3
    Newbie marchz24's Avatar
    Feb 2007
    Max Brakes does not make 2014 and up yet
  1. Replies: 2
    Last Post: 07-03-2016, 10:07 PM
  2. Front rotors, brake pads and rear shock replacement advice.
    By Figjam in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 12-01-2014, 12:47 PM
  3. Brake pads and rotor replacement ...where to go in TO/Markham?
    By user_nameless in forum Suspension & Brakes
    Last Post: 05-05-2008, 05:55 PM
