Results 1 to 10 of 10
Thread: Drivers Door wont lock with fob..
    Apr 2017
    Audi 6 speed
    5 Post(s)
    Default Drivers Door wont lock with fob..
    Hello, just picked up our 2010 Mazda 3 hatchback tonight. Just getting used to it, and noticed that the drivers door will not lock using the fob. All the other doors do lock with the fob, and all doors unlock. is this normal? Any idea why just one door will not lock with the fob?
    Rick
    Apr 2017
    Default Re: Drivers Door wont lock with fob..
    I think this should be posted in the Problems with the Mazda3 section - http://www.torontomazda3.ca/forum/fo...ith-the-Mazda3
    If you use the door lock on the actual driver's side door (not the remote), does the driver's side door lock? If not, then sounds like an issue with the door lock solenoid.
    Ontario
    If it momentarily locks, then unlocks on its own, then you have to replace the driver's door lock/striker module (it's all electromechanical and provides locking feedback to the body computer). I had to replace it in my 2010 a few years after purchase.
    Newbie credential23's Avatar
    Jul 2012
    Vaughan
    are you inside the car when you try locking the doors?
    Apr 2017
    Audi 6 speed
    5 Post(s)
    No, I would be standing outside the door while trying to lock it.
    Apr 2017
    Audi 6 speed
    5 Post(s)
    i dont think it momentary locks, but will check again.
    Sr Member Noisy Crow's Avatar
    Inside button work to lock/unlock?
    Apr 2017
    Audi 6 speed
    5 Post(s)
    yes inside button works, locking by key works, just not by key fob.
    Apr 2017
    Audi 6 speed
    5 Post(s)
    I think this is the problem. took the panel off and traced everything to this module. Will call the dealer tomorrow.
    I could not get it off completely, only loose. Do you happen to have disassembly instructions? some thing is still holding it in place.
    Apr 2017
    Audi 6 speed
    5 Post(s)
    correction, inside button does not work.
  1. Help door wont open !!!!
    By crank in forum Problems with the Mazda3
    Last Post: 04-15-2015, 12:24 PM
  2. Door Lock Actuator
    By sudz in forum Electrical
    Last Post: 07-27-2012, 03:37 PM
  3. Door doesn't lock
    By WildEmu in forum Trim & Interior
    Last Post: 06-29-2012, 02:22 PM
  4. driver door wont open
    By kal-el in forum Problems with the Mazda3
    Last Post: 06-15-2011, 10:23 PM
  5. Noise from drivers door panel since Door thingy was done
    By Bean in forum Problems with the Mazda3
    Last Post: 05-02-2008, 12:37 PM
