Results 1 to 2 of 2
Thread: Door Lock Module--taken apart- trying to fix it.
    Apr 2017
    German 6 speed and 5 spd
    5 Post(s)
    Default Door Lock Module--taken apart- trying to fix it.
    https://youtu.be/TY9xvjHdtqc
    I took apart the door lock module to try and figure out why it is not working. See part 1 at the above link.
    part 2 to follow.
    Rick
  2. The Following User Says Thank You to rdguy For This Useful Post:
    2012mazda3hatch (05-23-2017)
  3. #2
    Apr 2017
    5 Post(s)
    Default Re: Door Lock Module--taken apart- trying to fix it.
    Here is part 2. I took the round wheel with the teeth on it and moved it so that it would rotate more than the short distance in the 1st video. Once I did that , I was able to make the linkage work. Seems to be fixed but have not tested it with the electronics side. I Don't really want to take my door apart again, since I did buy a new one. Hope this is useful to someone. I did have to pry and slice open the seam of the module to get it apart, but the screws do hold it back together again.
    https://youtu.be/4Kquf6pW-hc
  4. The Following User Says Thank You to rdguy For This Useful Post:
  1. Fixed...Driver's door that would not lock.
    By rdguy in forum Problems with the Mazda3
    Last Post: 05-15-2017, 07:01 PM
  2. Hatch door Lock Rusting
    By dbear in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 09-04-2015, 07:35 AM
  3. Lubricant for door lock and hinge
    By kimy27 in forum Mazda3 General Discussion
    Last Post: 03-07-2014, 10:38 PM
  4. Door Lock Actuator
    By sudz in forum Electrical
    Last Post: 07-27-2012, 03:37 PM
  5. Door doesn't lock
    By WildEmu in forum Trim & Interior
    Last Post: 06-29-2012, 02:22 PM
