Results 1 to 10 of 10
Thread: Noise coming from font 2007 Mazda 3
    Nov 2013
    Ottawa/Gatineau
    Default Noise coming from font 2007 Mazda 3
    There is a noise coming from the front when driving over bumps but it's not like a metal on metal clunk more like a knock not to to loud. I jacked both front wheels and checked the play in the front suspension and eveyrything seems ok. I then drove up ramps and moved the swaybar up and down and there is very little play. I put my hand over the sway bar bushings as I was moving them and couldn't feel any play in them. Should there be any play in the end links? Or they should be really tight? Is it ok if I checked them while the car was on ramps and the wheels weren't hanging so the suspension would be unloaded?
    Orillia
    Default Re: Noise coming from font 2007 Mazda 3
    Endlinks should be tight. I would also check to make sure the spring isn't broken. I guess is it is your endlinks.
    Sr Member JonsMazda's Avatar
    May 2007
    Any oil leaking out from the shocks?
    Ontario
    My guess is ball joints. You have to take the load off of the suspension to properly check them for play, otherwise the strut keeps tension. Get a car jack and a 2x4 under the spring seat and compress the strut about 4" when you have it in the air.
    Nov 2013
    Ottawa/Gatineau
    Quote Originally Posted by morganc View Post
    This page
    http://www.wikihow.com/Check-Ball-Joints Part 2 Step 2
    says that if you have a McPherson strut front suspension, you need to
    Let the McPherson struts extend as far out as you can before you try to check the wheels for play.
    So I'm not sure, I thought you could check ball joint play with the suspension fully extended?
    97 Post(s)
    Its probably a ball joint. Gone through both sides already and had the same 'clunking sound over bumps'. You can check the ball joints when on a hoist easily, load off the suspension, pry bar look for excess movement.
    Ontario
    I am a pure believer in empirical problem solving and when my ball joints fubared, they didn't present themselves as faulty with the struts extended. When I took the load off, I was able to give the bottom of the arms a little tappy-tap with a rubber mallet and they moved around
    Quote Originally Posted by johnnyh55 View Post
    This page
    Mar 2017
    Have you replaced the front struts recently by any chance? When I did mine, I bought el-cheapo ones off eBay and installed them. The warning sticker on the new struts says not to touch the main spring nut so I presumed it was nice and tight. However, after driving for a couple of hours I was getting a similar noise to what you described which was resolved by tightening that main spring nut. Also might be worth checking the torque on the strut mount bolts. Good luck.
    Dec 2015
    A bad passenger motor mount can cause a knocking sound also.
    Nov 2013
    Ottawa/Gatineau
    So I just got around to fixing this over the weekend and for anyone who was wondering it was the front stabilizer links causing the issue. Now that they are replaced, no more noise.
  1. 2011 mazda 3 2.0 sedan, noise coming from rear passenger.
    By justmazduh in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 10-24-2016, 05:21 PM
  2. 2011 mazda 3 2.0 sedan 85km weird noise coming from rear passenger
    By justmazduh in forum Problems with the Mazda3
    Last Post: 03-20-2016, 11:46 PM
  3. Loud grinding/engine noise every 5-10 seconds / 2007 Mazda 3 2.0
    By JonfromOttawa in forum Problems with the Mazda3
    Last Post: 02-28-2013, 03:31 PM
  4. Replies: 10
    Last Post: 01-13-2013, 03:21 PM
  5. Replies: 0
    Last Post: 01-06-2013, 01:47 AM
