Results 1 to 14 of 14
Thread: Burning oil. Bad.
    Nov 2016
    Default Burning oil. Bad.
    Title says it all, 2004 2.3L Mazda 3 GS 5 speed manual, 240,000 kms. No leakage, black burnt oil, changed every 3000kms, oil filter housing appears to be perfectly fine.
    Did an oil change just the other day, 2L out "tops" maybe less, 5L in. I'm burning ALOT of oil. No luck on finding a cause so far. What do you guys recommend?
    Nov 2016
    Default Re: Burning oil. Bad.
    Coolant is perfect in colour by the way, forgot to add that.
    May 2012
    53 Post(s)
    Double post!
    May 2012
    53 Post(s)
    Check you PCV on your crank case, it may have pooched itself and is stuck open. Not the most fun to access but the part itself is cheap.
    This would cause you to burn lots of oil if it's stuck open. @LinkinEffect
    Nov 2016
    Quote Originally Posted by pwdunmore View Post
    Double post!
    I apologise, is that against the rules? I'll know for next time.
    Nov 2016
    Will look into it, thank you! Could anything else cause the oil to burn? I've also heard the Piston rings?
    97 Post(s)
    Quote Originally Posted by LinkinEffect View Post
    If it was your rings you'd be seeing blue smoke out of the exhaust, and with the amount your going through most definitely smell it.
    If you've found no leaks and your coolant is clear there's only two other options your valve seals or PCV valve, and I would suggest your PCV to be the culprit.
    Nov 2016
    Will give it a go, no sign of blue smoke so I guess that's a good sign! The car runs pretty clean actually, no exhaust smoke at all.
    May 2012
    53 Post(s)
    You didn't double post my browser did so I deleted my double post.
    Keep looking for the issue, search for oil residue in the intake manifold for a bad PCV valve. There would be a considerable amount not just a fine misting, if the valve is bad.
    Mar 2006
    East GTA
    2010 M3 GX Sport
    The 2004/2005 were famous for burning oil in the 2.3L engine. My 2005 burned oil at a rate of 1L per every 1,000km so I always had a jug of motor oil in the trunk and checked oil frequently and topped up when required. No oil leak on the driveway and no smoke out the tail pipe.
    19 Post(s)
    the true cause of the problem is running piss thin 5W20 oil... switch to 5W30 like what's used in Europe, and it takes care of the problem... on a high mileage motor, it has worn down due to running the thin oil, so running 30 weight oil won't stop the burning but slow it down
    Nov 2016
    I'm already running 5W30,
    19 Post(s)
    If you bought your car used, it likely would have worn down already due to using the 5W20 oil and using 5W30 only helps marginally
    Ontario
    Try substituting 500mL of Lucas Oil Stabilizer (Canadian Tire) in every oil change. It has worked wonders on many engines in my life.
  1. Burning Oil
    By gularti in forum Engine & Drivetrain
    Last Post: 08-01-2012, 06:28 PM
  2. Burning Oil
    By mazdaagain in forum Engine & Drivetrain
    Last Post: 11-30-2011, 12:06 PM
  3. burning smell from sub?
    By thanu31 in forum I.C.E (In-Car Entertainment)
    Last Post: 07-11-2010, 01:05 AM
  4. ... Is something burning?
    By towelsnap in forum Pictures and Videos
    Last Post: 09-02-2009, 07:48 AM
  5. DVD burning questions
    By Dr Butcher in forum General Lounge
    Last Post: 09-14-2004, 02:34 PM
