Results 1 to 12 of 12
Thread: Rattling from rear of car
    Nov 2016
    Default Rattling from rear of car
    The rattling happens when I go over any sight bump or even a crack in the road it rattles bad. I just replaced rear end links thinking that was the issue. It stops when I apply the brakes. My rear struts are leaking and will be replaced but I still don't think that's causing this rattle. I'll leave a link to the video. Please help, it's driving me insane. https://youtu.be/9HQRVgv9X-Q
    Sent from my Pixel XL using Tapatalk
    Mar 2017
    Newmarket
    13 Post(s)
    Default Re: Rattling from rear of car.
    Check to see if the exhaust is loose as rattling against something.
    Nov 2016
    Quote Originally Posted by Derek195 View Post
    This isn't an exhaust rattle
    Mar 2017
    Newmarket
    13 Post(s)
    Quote Originally Posted by Bryce0921 View Post
    It's probably the struts then. Jack up the rear of the car and see if you can replicate the noise by wiggling the wheels.
    Nov 2016
    I found my brake cable was rattling maybe that's the problem
    Mar 2017
    Newmarket
    13 Post(s)
    Could be possible. Secure it and see if it went away.
  7. The Following User Says Thank You to Derek195 For This Useful Post:
    Bryce0921 (06-07-2017)
    Feb 2017
    Guelph
    Mazda B-2300
    Could it be the spare tire or in the jack compartment? Mine was rattling once so I secured it better and it stopped
    Nov 2016
    Quote Originally Posted by 2012mazda3hatch View Post
    Its definitely outside the car but I'll check that anyway, thanks!
  10. #9
    Nov 2016
    That wasn't it, when I pull ebrake slightly, it stops rattling
  11. #10
    Uncle Ben
    Sep 2005
    37 Post(s)
    check tightness of wheels.
    This sounds EXACTLY to what I had an issue with. SLIGHTEST brake application and the noise would go away. On a hoist, had the hand brake on and was checking the rear end and was able to turn the wheel on one side. tightened lug nuts, noise gone
    less likely, due to conditions you are describing maybe your rear coils are broken. the bottom coil will break about half a wind. It will rattle like no tomorrow in your lower control arm
    1991 Nissan Pathfinder SE-V6 Red/red interior - trade in
    2005 Mazda 3 GX ty grey/black interior - Write off
    2010 Mazda 3 GT E sedan Crystal White Pearl/on black interior- trade in
    2010 Speed 3 Crystal White Pearl/on black interior all options- current
    2007 Mazda 3 GS silver- current winter ride
    2002 BMW 330ci silver- new toy
  12. #11
    Nov 2016
    Fixed it, brake pads were rattling
  13. The Following User Says Thank You to Bryce0921 For This Useful Post:
    Mazduh (06-12-2017)
  14. #12
    Ontario
    Nice, I had the same issue last summer. It drove me nuts; two new brake caliper anti rattle springs and I was good to go.
  15. The Following User Says Thank You to morganc For This Useful Post:
    Bryce0921 (06-26-2017)
  1. Rear deck lid rattling
    By MikeSafari in forum Problems with the Mazda3
    Last Post: 02-10-2017, 05:25 PM
  2. Rattling at rear window
    By aris in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 08-27-2014, 09:41 AM
  3. Rattling clunking noise from rear?
    By bluemazda3 in forum Problems with the Mazda3
    Last Post: 06-13-2011, 10:01 PM
  4. Annoying rattling sound rear top of car
    By rage2021 in forum Problems with the Mazda3
    Last Post: 04-23-2011, 09:13 PM
  5. Rear strut rattling noise
    By CanSpeed 3 in forum Suspension & Brakes
    Last Post: 06-04-2008, 10:33 PM
