Results 1 to 6 of 6
Thread: Rattling from rear over small bumps.
    Newbie bmxjordanbmx's Avatar
    Oct 2015
    Default Rattling from rear over small bumps.
    I'm getting a loud rattle from the rear of the car over small bumps, both shock mounts have been replaced. Brakes have been done and don't rattle, and also new sway bar links. Don't have a clue what it could be. Shocks are also not leaking. Happens most at low speeds.
    I drive a 2007 Mazda 3 2.0
    Any help would be greatly appreciated, thanks in advance.
    Sent from my LG-H831 using Tapatalk
    Nov 2016
    Default Re: Rattling from rear over small bumps.
    Quote Originally Posted by bmxjordanbmx View Post
    Do you have a video? I had a rattling from the rear of my 08 speed 3 and I couldn't figure it out. Came to realize my brake pads were rattling. Who would of thought? Only other thing I can think of if you're sure it isn't that is maybe your spare tire.
    Sent from my Pixel XL using Tapatalk
    Apr 2017
    German 6 speed and 5 spd
    5 Post(s)
    Exhaust hanger broken? E-Brake cables? look for the simple stuff.
    Oct 2015
    Quote Originally Posted by rdguy View Post
    Cables are good, will check brake cables, thanks!
    Member sarujo's Avatar
    23 Post(s)
    End links and rear sway bar bushings are often primary culprits for rear end noise. Since your links were changed, check to make sure they are still tight and did not back off. I had to go with loctite on my end links after upgrading my RSB...end links loosened in a couple of weeks.
    Good luck in the search
    2010 Sport 2.0L 5MT
    Sr Member Noisy Crow's Avatar
    I had a broken exhaust hanger on my '08.
  1. Rear end noise when going over bumps
    By Booter22 in forum Problems with the Mazda3
    Last Post: 03-03-2017, 08:53 AM
  2. Rear Knock on Bumps
    By ValdesX in forum Problems with the Mazda3
    Last Post: 12-13-2013, 02:41 AM
  3. Mazda3 2011 Bounces and rattles over small bumps
    By Red Mist in forum Suspension & Brakes
    Last Post: 12-05-2012, 05:52 PM
  4. Noises when going over small bumps
    By Iceman_F1 in forum Problems with the Mazda3
    Last Post: 10-29-2011, 09:42 AM
  5. Rattling noise over bumps
    By last_shot in forum Problems with the Mazda3
    Last Post: 09-24-2011, 05:15 PM
