Results 1 to 3 of 3
Thread: Is there a way to tell if I have a Hpfp without pulling it.
    Newbie Teh_baje's Avatar
    Nov 2015
    Default Is there a way to tell if I have a Hpfp without pulling it.
    I bought a gen 2 speed around a year and half ago from a dealership. I could tell that it was returned to stock and I got a good price on it.
    I installed a Sri and Tip and that's it. The car runs fine but after hearing horror stories about fueling I decided to check out the fuel pressure with torque. It peaked at 1980 psi at WOT in 3rd and 4th, average at about 1750 in 5 pulls. Also AFR IS SPOT ON 14.5:1 at idle and 11.5:1 at WOT. I'm planning to do the Hpfp in 2 weeks but if I don't need it that money could go to an access Port.
    Jr Member ricola's Avatar
    Dec 2013
    Guelph
    2011 Acura RDX
    35 Post(s)
    Default Re: Is there a way to tell if I have a Hpfp without pulling it.
    I trusted my logs when I was tuning my car. They say to pull them and check but if you're holding steady at wot in your logs from 2k to redline it's like 99%. Especially in a Gen pu
  3. The Following User Says Thank You to ricola For This Useful Post:
    Teh_baje (08-05-2017)
    Nov 2015
    Quote Originally Posted by ricola View Post
    Thanks for the reply, I will pull it next weekend and check just to be safe.
  5. The Following User Says Thank You to Teh_baje For This Useful Post:
    ricola (08-05-2017)
  1. Pulling fenders
    By mazda3t in forum MazdaSpeed 3 Forum
    Last Post: 06-10-2016, 06:10 PM
  2. Mazda3 pulling to the right
    By Joshua in forum Wheels & Tires
    Last Post: 12-15-2014, 09:52 AM
  3. Pulling right after alignment
    By tpirovol in forum Wheels & Tires
    Last Post: 08-27-2012, 12:58 AM
  4. car pulling to the right
    By ///M in forum Problems with the Mazda3
    Last Post: 03-11-2007, 11:19 PM
  5. Car pulling to the lef
    By MAZDA Kitten in forum Problems with the Mazda3
    Last Post: 09-16-2005, 02:06 PM
