Results 1 to 3 of 3
Thread: What is the size/OEM part number for a ball-joint pinch bolt?
    Mar 2016
    Default What is the size/OEM part number for a ball-joint pinch bolt?
    I'm swapping the front wheel bearings on my '05 Mazda3 this weekend, and the lower ball joint bolts look like they wont come off unless I want to cut it right down the middle. Corrosion has gotten the best of them, and the socket will just skip over the hex and strip the crap out of it. Where can I find the OEM P/N for this bolt/nut pair? I found the shop manual online, but it doesn't specify the size of the bolt/nut etc. anyone have any idea?
    This is for the pinch bolt at the bottom of the steering knuckle, which is pinching it onto the lower ball joint.
    TIA
    Default Re: What is the size/OEM part number for a ball-joint pinch bolt?
    14mm
    2010 Mazda3 Graphite Mica GS Auto with Comfort Package
    Oct 2012
    Durham
    GJ21-34-098B. Any good dealer will have them in stock.
  1. Loose Ball Joint - Will I Die If I Drive?
    By WhiterThanChalk in forum Suspension & Brakes
    Last Post: 01-30-2016, 11:01 PM
  2. Ball joint and clunking noises
    By Jmboxer21 in forum Suspension & Brakes
    Last Post: 05-14-2015, 04:41 PM
  3. Seems Like I am Always Replacing Ball Bearing/Joint...
    By VCM in forum Problems with the Mazda3
    Last Post: 02-12-2014, 07:33 AM
