Results 1 to 4 of 4
Thread: HELP!!! Brake caliper piston tool...
    Aug 2010
    Default HELP!!! Brake caliper piston tool...
    Doing my back brake pads and rotors on my 2014 mazda3.. I've replaced my front ones before on my old car and figured it would not be much different...
    I was finally able to compress the caliper piston using the tool from partsource, which by the way was not a perfect fit and at first kept sliding off, but now I can't remove the tool... I keep trying to unscrew it but the piston wont move and so the tool seems to be jammed on....
    I'm wondering now if I missed a step.. Was i supposed to remove the parking brake wire, also I see there is a little spring behind the caliper.. what does that do? What about the bleed valve?
    Thanks for any help...
    Jr Member MikeTheCheek's Avatar
    Sep 2013
    26 Post(s)
    Default Re: HELP!!! Brake caliper piston tool...
    So you can't lower the tool to remove it? Take an open ended wrench to the tool and hold that to loosen the tool.
    Aug 2010
    Thanks... Actually I figured it out... It was pretty obvious. Guess the brain just didn't want to work for a bit there..
    Hey... Would anyone know the torque specks? I tighter the caliper mounting bracket bolts to around 60 lbs (w/ locktight) and the caliper pin bolts to around 20 lbs...
    Thanks...
    Mar 2014
    56 Post(s)
    I bought this tool and it worked just fine
    https://www.amazon.ca/8milelake-21pc...dp/B019XLTC00/
    Why would you take all the wires off?
  1. Looking to borrow/rent rear caliper tool
    By hondaciviceg in forum Mazda3 General Discussion
    Last Post: 05-12-2014, 05:33 PM
  2. Wilwood 4 Piston Brake kit
    By mikey32235 in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 02-04-2014, 10:47 AM
  3. Rear Caliper tool DIY
    By Dave_The_BMXER in forum Suspension & Brakes
    Last Post: 04-05-2010, 12:00 AM
  4. Caliper Lubing Question + Brake Caliper Tool Set
    By liquidzyklon in forum Suspension & Brakes
    Last Post: 03-22-2010, 10:24 PM
  5. brake caliper
    By al01 in forum Exterior Styling & Appearance
    Last Post: 03-09-2005, 07:14 PM
