Results 1 to 8 of 8
Thread: Rear Sway bar end links
    Nov 2009
    Waterloo, ON
    18 Post(s)
    Default Rear Sway bar end links
    Can you put MS3 rear Sway bar links on regular 3 (second gen)? As far as I read MS3 endlinks have 12mm shafts vs 10mm for MZ3...could I just drill 2mm out of my stock Rsb?
    Sent from my D6603 using Tapatalk
    2010 Mazda 3 GS (daily driver)
    2008 Mercedes-Benz C230 4MATIC Sport + Premium Package (wife's car)
    1991 Honda Civic Hatchback DX (parted and wrecked)
    394 Post(s)
    Default Re: Rear Sway bar end links
    Sr Member Reddie1337's Avatar
    Feb 2012
    Oakville, Cambridge
    Speed or S/O's 3 2.Slow
    260 Post(s)
    That would probably take a lot of work. The sway bar is a very heavy piece of metal. I do not see a reason to drill them? It's the same style of link. Is there a reason you don't want to replace with the same size?
    And of course I'd get tagged. I work on these enough eh @S.F.W.
    Mods to Date:
    Nov 2009
    Waterloo, ON
    18 Post(s)
    MS3 endlinks are beefier so that is the reason. How does that work with upgraded Rsb on MZ3, you keep you stock endlinks with smaller shafts or you would need to get ms3 links then?
    71 Post(s)
    I've had stock end links on my mz3 with a MS3 rear sway for 9 years. All I did was have some spacers made for them and that took up any slack. They have yet to break. *knock on wood*
    http://s210.photobucket.com/user/cwp...pacer.jpg.html
    Attached Images Attached Images
  6. The Following User Says Thank You to cwp_sedan For This Useful Post:
    r4BBiT (09-05-2017)
    Nov 2007
    i bought some MS3 endlink from Rockauto, priced really well, check them out, no surprise at my door delivery as well.
    Jr Member ptgrad2012's Avatar
    Aug 2012
    I bought moog end links for mazda 3, forgetting that i have jbr sway bar ( ms3 spec). So what i ended up with was some clunking over small bumps since theres a gap.
    Nov 2009
    Waterloo, ON
    18 Post(s)
    Quote Originally Posted by ptgrad2012 View Post
    Sorry for late reply, but the whole point of me changing my end-links that I can't take the clunking anymore....I drove like that for a year and it annoying after a while.
    Either way I installed stock MZ3 end-links.
  1. Rear sway bar links are toast
    By js593 in forum Suspension & Brakes
    Last Post: 12-04-2015, 08:09 PM
  2. Sway bar links
    By ssolidd in forum Problems with the Mazda3
    Last Post: 07-04-2015, 08:23 PM
