Results 1 to 4 of 4
Thread: Rear koni blew out =(
    Jr Member ptgrad2012's Avatar
    Aug 2012
    Question Rear koni blew out =(
    hi all,
    So my rear koni yellow blew out today (driver side) with oil leaking after about 120 000 km. I am on eibach prokit springs
    I emailed koni for the warranty replacement program, but I think there will be some downtime (application processing, shipping)
    Since the milage on the rear passenger is about the same, assuming it's near the end of its life, I should probably change it as a pair right?
    Would I be buying a new rear shock from koni and have 1 free replacement. So technically, the life time warranty usually doesn't cover everything since you have to buy one for the opposite side most of the time.
    So in the meantime while waiting, would it be okay
    -to drive the car at city speed (60km/h) and slow cornering? would it cause damage to the car (there is quite a bit of clunking when driving)?
    -or should I temporarily put in the stock shock for now and drive slowly
    Thanks in advance
    393 Post(s)
    Default Re: Rear koni blew out =(
    Quote Originally Posted by ptgrad2012 View Post
    hi all,
    Thanks in advance
    Depending where you purchased the shock, many re-sellers will help you with an advance RMA. You buy one new shock, you replace the blown shock, they return the blown shock to Koni, they get refund, then you get a refund.
    Aug 2012
    I got it from alphamotor's Mo back in 2013, do you know if he's does this service?
    393 Post(s)
    Not sure, but I expect he would.
  1. New Koni install, rear clunking?
    By cy88 in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 02-19-2013, 06:21 PM
