Results 1 to 2 of 2
Thread: 2010 Mazda 3- rear noise after new front struts
    Oct 2017
    Default 2010 Mazda 3- rear noise after new front struts
    Hello,
    I purchased a 2010 Mazda 3 sedan earlier this year and soon after, a mechanic changed my rear stabilizer links and the rear left shock. Recently, my front struts started leaking, so I changed those myself. But now, when I drive over bumps (even the slightest crack in the road), it sounds like something at the back of the car is loose and it makes a lot of noise.
    I'm wondering if it's possible that the stabilizer links got loose and how I can check that. If there are any other suggestions, please let me know.
    Thanks very much for the help.
    Ontario
    Default Re: 2010 Mazda 3- rear noise after new front struts
    This could be a few things. #1, the nut that tightens the rear strut rod to the mount could be loose. I had this happen to me and had to apply loctite blue to it to keep it from backing off. If you're good, you can access the tops of the struts by peeling back the rear trunk liner, rather than removing the struts.
    Stabilizer bar links are easy to check for loose fasteners; crawl underneath with your wrench and try to give 'em a twist!
  3. The Following User Says Thank You to morganc For This Useful Post:
    10Mazda3 (10-17-2017)
  1. Weird cricket chirping noise, front suspension. Clunk in rear.
    By starlaspeed3 in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 08-14-2012, 09:55 PM
  2. Mazda 3 2004 Front-end struts shot
    By koz in forum Problems with the Mazda3
    Last Post: 09-25-2010, 09:42 PM
