Results 1 to 6 of 6
Thread: one side of rear wheel free spins faster?
    Nov 2013
    Ottawa/Gatineau
    Default one side of rear wheel free spins faster?
    when i was at the mazda dealer for an oil change on my 07 Mazda 3 gt the service advisor said my right rear caliper was starting to seize. so i got home and jacked up the rear wheels and spun both sides with the parking brake off and the right side made less turns than the left side. so i thought sure enough it's starting to seize so i bought a new caliper and installed it. bled the brakes and it's the exact same thing. what could cause this? can the parking brake cable seize and not fully release?
    Sent from my SM-G930W8 using Tapatalk
    Ontario
    Default Re: one side of rear wheel free spins faster?
    If you want to make completely sure, take both calipers off and try the same test. You could also have one wheel bearing that more worn than the other, causing the excess friction. If you have a seized caliper, then you'd more than likely see a host of other problems (poor wear, possibly over heating). Have someone pull the parking brake while you have the wheels off and observe the bell-crank on each caliper. Make sure they're moving about the same.
  3. The Following User Says Thank You to morganc For This Useful Post:
    shift8 (10-22-2017)
    Member shift8's Avatar
    Jun 2013
    Alliston, ON
    Toyota Highlander Limited
    51 Post(s)
    I had to replace my rear hubs too.
    Sent from my LG-H915 using Tapatalk
    2008.5 Mazdaspeed 3, CWP
    JBR SRI + TIP - AutoTech HPFP - CP-e TMIC - Cobb RMM
    TWM short shifter w/ bushings - Saikou Michi OCC - Damond EGR block off + delete - Continental ExtremeContact Sport
    Enkei RPF1 (white) - CS stubby antennae - Guardian Angel - Cobb AP - vanity plate
    Sr Member Noisy Crow's Avatar
    Yes, parking brake can stick. Corrosion in the cables is the most common reason.
    Nov 2013
    Ottawa/Gatineau
    Well I just adjusted my parking brake cable and ran out of adjustment so I guess the cable is stretched and needs to be replaced. So I don't think that it is sticking. I would have to remove the caliper or just the pads and bolt the wheel back up and spin it, then I could tell if it's the brakes that are hanging.
    Orillia
    If it is still spinning fairly easy it shouldn't be much of an issue. A wheel bearing you will start to hear get louder in the rear. If there isn't excessive brake pad wear then I wouldn't be concerned.
  1. Replies: 5
    Last Post: 09-02-2015, 06:11 PM
  2. Rear wheel spins freely in park
    By 05gt3 in forum Problems with the Mazda3
    Last Post: 06-21-2013, 10:52 AM
