Results 1 to 4 of 4
Thread: Moisture inside headlight assembly ('05 Mazda 3 hatch)
    Noob SetZ0's Avatar
    Nov 2017
    Default Moisture inside headlight assembly ('05 Mazda 3 hatch)
    Hi there, I'm new to this forum. My driver side headlight on a Mazda 3 2005 hatchback GS has moisture/water inside. I noticed it about 2 weeks ago and since it has been raining in Toronto for the past few days, the amount of moisture inside has been really more noticeable. The passenger side doesn't have this issue at all.
    I've been looking up how to fix it and a leak will most likely need to be sealed (not really comfortable doing this by myself). If not, I was also thinking of buying used OEM headlight assembly for the driver side and have it installed by my mechanic. I haven't done much research into aftermarket HIDs (I saw some being sold anywhere from $200-$400 for left & right headlight) but if I was to buy them and have it installed somewhere, how much would it cost?
    I really appreciate if you guys could give me some advice/tips on what to do. Thank you!
    Feb 2017
    Guelph
    Default Re: Moisture inside headlight assembly ('05 Mazda 3 hatch)
    @Hyperion can hook you up with some headlights.
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    252 Post(s)
    Hey,
    Either you can diy, just open them in the oven, 225 for 15, and add some of this: http://www.gtaretrofits.com/shop/hid...butyl-sealant/
    Or I can do that for you. You'd have to provide the headlights off the car. Send a pm if you'd like to arrange a time for me to do it. Or you can purchase the butyl off the site at any time.
    Noob SetZ0's Avatar
    Nov 2017
    Hey thank you all for the reply! I will send a pm
  1. Moisture going into the headlight housing
    By koorick in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 03-09-2011, 07:52 PM
  2. Moisture inside the Fog light cover.
    By Garu in forum Problems with the Mazda3
    Last Post: 02-17-2009, 11:21 AM
  3. Moisture in driverside headlight
    By miggiddy in forum Problems with the Mazda3
    Last Post: 07-04-2005, 09:35 AM
