Results 1 to 6 of 6
Thread: Cruise controls stops working after a few minutes
    Jan 2012
    Default Cruise controls stops working after a few minutes
    Hey guys my cruise on my 2010 mazda 3 hatchback was working fine till I came back from being away with work for 3 weeks, the car sat in the driveway, the day after I came back the car started fine and I took it for a drive on the highway and noticed that the cruise control turns on but after 1 or 2 minutes it automaticly stops working, I can put it back on and then it stops. The cruise light stays on, just goes back to yellow.
    Had this problem for a few weeks now, have some of you had issues with it?
    The car has 222 000 km on it if it helps.
    thank you
    Dec 2013
    Default Re: Cruise controls stops working after a few minutes
    No "Check Engine" light? Maybe get a code scanner to see if you're throwing codes (though curious that the light wouldn't come on).
    129 Post(s)
    Quote Originally Posted by Ps3alltheway View Post
    thank you
    do you have two mats in the car?
    Costco = good cheap solution
    It's like a buck a nut
    Jan 2013
    B-Town
    Could be an issue with the cruise control module or the sensor on your brake pedal that disables it. If is just stops working then module may be shot. Maybe check all connections?
    there's no cruise control modules in these cars... it's all controlled by the ECU through the drive-by-wire throttle
  6. The Following User Says Thank You to TheMAN For This Useful Post:
    RustyMZ3 (12-25-2017)
    Jan 2012
    I've had a check engine for a few years now but it is 02 sensor and yes I do have 2 mats (the one that comes with the car and one winter mat on top of it) like I always do.
  1. windshield wipers squeal , sometimes stops working
    By trademark83 in forum Problems with the Mazda3
    Last Post: 09-16-2015, 10:20 AM
  2. Ipod Adapter Suddenly Stops Working
    By wak9 in forum Electrical
    Last Post: 12-20-2010, 11:09 PM
  3. ABS Lights are on + Cruise Control Not working
    By Tsirpas in forum Problems with the Mazda3
    Last Post: 02-22-2009, 06:09 PM
  4. Dome light stops working once LED installed?
    By Mafty in forum Exterior Styling & Appearance
    Last Post: 07-28-2008, 07:57 PM
