Results 1 to 15 of 15
Thread: HEEEEEEELLLLLLPPPPPPPPPPPPPPP No Starter Function!
    Newbie Sock Monkey's Avatar
    May 2011
    Default HEEEEEEELLLLLLPPPPPPPPPPPPPPP No Starter Function!
    OK I took the 2006 Mazda 3 out today and it won't start. It's been having some laboured starts when it's cold recently causing me to THINK about the battery but it's not to that point yet. Today it started just fine and drove 10km to the store and when I came out, nothing. Turn the key on and the entire electrical package comes on. Radio, wipers, bright dash lights, etc. etc. Door chime is OK. No problem but, there is absolutely no response to the key / starter system. No slow starter, no grinding, I don't even remember that the dash lights dim or anything. Just no starter. So, I boosted it. It made no difference. The battery seems OK but no starter.
    So, is there a starter relay or starter fuse I should be looking at?
    Thanks for any help.
    Monkey
    Default Re: HEEEEEEELLLLLLPPPPPPPPPPPPPPP No Starter Function!
    Take it to a shop and have your system and components checked. Battery is probably toast.
  3. The Following User Says Thank You to Flagrum_3 For This Useful Post:
    Sock Monkey (02-22-2018)
    Orillia
    Could easily be the starting motor. Give it a good wack, it is just on the front.
  5. The Following User Says Thank You to jeff7670 For This Useful Post:
  6. #4
    May 2011
    Yeah, I'll have a dig around. Look for a bad connection on the starter or whatever. I don't see how it could be the battery if boosting didn't help.
  7. #5
    May 2011
    OK, got up this morning and it started so I had a chance to load test it. 12.4 volts cold. Drops down to around 7 or 8 while cranking and pops back up to 11-12 area. I think it's pooched. Also, it's a clear body Panasonic battery so I think it's original to the car. Not bad, 12 years out of a battery.
    Thanks for your help.
  8. #6
    Uncle Ben
    Sep 2005
    Long time known issue, the trigger wire for the starter corrodes and caused no crank situations. Pull the splash shield and check the connector. Doesn’t necessarily need to be corroded. Take some sand paper and scrub the terminals. Happened on mine when I changed the transmission
  9. The Following User Says Thank You to McGuyver_3 For This Useful Post:
    Sock Monkey (02-23-2018)
  10. #7
    May 2011
    I'll look at that when it quits snowing. I have my battery tender on it but I think something is wonky with the battery tender. It's supposed to be yellow light until charged and then red light for charged. This just goes yellow light for about a second when plugged in and then they all go off. It could also be the bad battery too. Before I get too worried about it I will check that starter trigger wire as you suggested McGuyver. Thanks.
  11. #8
    May 2011
    The saga continues. I charged the battery fully. Drove it for an hour, stopped and it wouldn't start. Turn on the key, the dash lights light up just fine. Headlights are on nice and bright. Hit the starter and the LCD radio display goes out of course but all dash lights stay on nice and bright. Fuel pump buzzes for a second or so and stops. Turn the key, no starter. My pal thought he might hear a bit of a clicking. We hooked up the booster cables, nothing. As McGuyver suggested, I had already removed both wires from the starter, high power lead and the trigger wire. Cleaned contacts and replaced with dilectric grease on them. With the car boosted, nothing. I turned on the key and tried it about 15 times in a row, just bouncing it against the switch spring thinking I might hear a clicking. My pal said "Come out here and listen" so I got my head down, he jumped in and hit the switch and it started just like that.
    Brought it home and did another drawdown test on the battery and it was fine but I bought a new battery. It doesn't work.
    Is there a starter relay anywhere on these or do the starters have a bendix like the old ones did? There seems to be an inconsistency in the starter switching circuit because when it does decide to start, it's a good strong crank.
  12. #9
    Uncle Ben
    Sep 2005
    This is starting to sound more and more like a bad starter in general. If you have a friend with you when it doesn’t want to start, try tapping the the starter. Generally that will make it work. That’s the easiest test before overthinking this
  13. #10
    May 2011
    I could easily see that. I will try the tappy test. Can they be unstuck if that's the problem or do they generally need replacing?
  14. #11
    Uncle Ben
    Sep 2005
    At work I've always replaced them, never tried fixing one before.
    On the 3, for about 80$ used (based on pricing +/- 9 years ago) and 20 minutes worth of time for instal, I didn't think twice. Might want to check what a new one is worth as well. Prices should have definitely dropped since then
  15. The Following User Says Thank You to McGuyver_3 For This Useful Post:
    Sock Monkey (03-07-2018)
  16. #12
    Jr Member Shawn's Avatar
    Nov 2007
    Maybe bad commutator in the starter. I had similar with older car.
    Regards
    Shawn
  17. #13
    May 2011
    TAP TAP,,,,,,,,,,,, ZOOM! ZOOM! Off to Lordco tomorrow for a $73.00 starter.
  18. #14
    May 2011
    Including tax, $166 for the new starter and that's after they refunded me for the core. I thought that was a lot of money. I have to say that if I had spindly little girl arms with about 3 elbows on each one and eyes on my finger tips the job would have gone a lot easier. Still, it's in and working.
    Thanks for the help.
  19. #15
    Uncle Ben
    Sep 2005
    166 is cheap. We have a few that range upwards of 600$ Lol
    Glad it’s all working
  20. The Following User Says Thank You to McGuyver_3 For This Useful Post:
    Flagrum_3 (03-21-2018)
  1. Search function help
    By peterm15 in forum Site/Server issues and suggestions
    Last Post: 06-18-2011, 05:34 PM
  2. Edit function: still not present
    By Google in forum Site/Server issues and suggestions
    Last Post: 04-18-2011, 02:29 AM
  3. Edit function
    Last Post: 09-17-2009, 12:51 AM
  4. HID Mal-function
    By Hazy in forum Lighting, Electrical & Security
    Last Post: 11-21-2005, 08:59 AM
