Results 1 to 8 of 8
Thread: So umm my key broke. How do I fix/replace this?
    Feb 2011
    Default So umm my key broke. How do I fix/replace this?
    It's cracked where it holds the key. I have a spare and this one still works but I'd rather replace it before I need it or if I lose the other key. I know the key part can be removed from the remote part, but is it as simple as getting a new key key blank and replacing it?
    Feb 2011
    Default Re: So umm my key broke. How do I fix/replace this?
    I forgot to mention it's a 2011
    Feb 2017
    Guelph
    To get a new key from the dealer is about 400$ for the fob and the key to be programmed. When this happened to me I just went to Canadian tire and got them to cut me a new one. Some locations now do chip keys and I haven’t had any issues with it.
    Buy a replacement fob used on eBay or similar. Then have a dealer cut and insert cut key into fob you bought online.
    You can program the key yourself since you have two keys already programmed.
    Noob KaylaHeart's Avatar
    Mar 2018
    Pontypool, Ontario
    93 Ford Probe GT Modified
    It Looks like you just broke the fob i'd see if you could find one similar and change out the broke fob part.
    Uncle Ben
    Sep 2005
    you can buy the blade portion separate from the remote portion
    example, click it
    They should be in the 50$ range at the dealer from what I remember. I don't suggest that ebay link, just using it as an example
    Jr Member Flunk's Avatar
    Dec 2009
    2021 CX-30 GT Turbo
    Were it me, I'd first try taking the key apart and gluing the broken plastic back together. Use either a plastic specific epoxy or if you can't find that the super glue will hold ok for a spare key. It should continue to work properly provided the plastic part clears the housing
    Aug 2015
    Not sure if you replaced the key yet, but you can buy the blade off of ebay for around $5. You can get the blade cut and replace it yourself.
  1. someone broke into my car!!!
    By drkpsngr in forum New User's Lounge
    Last Post: 10-28-2014, 11:48 PM
  2. I Broke It.
    By joedemarco in forum MazdaSpeed 3 Forum
    Last Post: 10-10-2014, 10:41 PM
  3. My Mazdaspeed CAI broke...
    By Dan Da Man in forum Performance
    Last Post: 04-10-2014, 09:46 AM
  4. 3 broke down
    By Twhite71 in forum Engine & Drivetrain
    Last Post: 08-31-2013, 10:06 AM
  5. I think I broke something on my MS3
    By Skyhigh in forum MazdaSpeed 3 Forum
    Last Post: 03-31-2009, 04:24 PM
