Results 1 to 6 of 6
Thread: 2005 Mazda3, 109K Trailing arm bushing
    7 Post(s)
    Default 2005 Mazda3, 109K Trailing arm bushing
    Was at the dealer the other day and they reminded me about my rear driver's trailing arm bushing a few years ago. Now, it needs replacing. I checked prices at rockauto and unfortunately, they didn't have my trailing arm. Amazon has it but it's close to $300. Not sure if that's the correct price.
    This is a major job, but I was wondering if it's better to get the entire trailer arm replaced at another shop or just the bushing?
    Made in BC.
    Default Re: 2005 Mazda3, 109K Trailing arm bushing
    Unless the trailing arm is bent somehow, I suggest just changing the bushing. They are like $20 ea. The cost is in installing them, as usual. Search around at independent shops and get quotes. The dealer will simply overcharge on the labour at the tune of $110 per hr or more.
    As an example; I had both of my rear bushings changed out along with a myriad of other suspension components at around 280k on my MZ3. Including; Sway bar bushings & clamps, shocks & struts, both front lower control arms and stabilizer arm links all for $600 labour at an independent near me. Mazda wanted almost $1600 in labour to do the same.
    Its your choice.
    7 Post(s)
    Thanks Flagrum. When you mean independent, would shops like Midas be included or should I stick with specialty independent shops instead?
    Orillia
    Independent is best. I find they are much more honest and do better work then Midas. Usually mechanics at independent shops have been there for 10+ years. Once you find a good shop, stick with it.
    Quote Originally Posted by Google View Post
    Absolutely no to Midas! Any of the "Chains" are rip-offs for the most part.
    Look for an true independent, a family run place. Ask friends or around for referrals, word of mouth is usually the best method.
    Good luck,
    Member shift8's Avatar
    Jun 2013
    Alliston, ON
    Toyota Highlander Limited
    54 Post(s)
    I'd agree on the bushing replacement. I had to swap my trailing arms after a dealer crushed the shock mount point. Not cheap
    Unless they are bent or rusted to shit, the labour is basically the same to replace them since they have to come out anyways. If the bushing is significantly cheaper than just have a new one pressed in.
    2008.5 Mazdaspeed 3, CWP
    Forged internals + GTX2871r
  1. Jsac2284 - 2005 Mazda3 GT - 2012 Mazda3 GS Skyactiv
    By Jsac2284 in forum Member Rides
    Last Post: 05-25-2013, 08:32 AM
  2. Hi All! 2005 Mazda3 GT
    By phreez2011 in forum New User's Lounge
    Last Post: 10-16-2012, 08:39 AM
  3. 2005 Mazda3 GS
    By Tuga in forum Mazda3 General Discussion
    Last Post: 10-02-2008, 09:28 PM
  4. 2005 Mazda3 GT...
    By PiCASSO in forum Buying a Mazda3
    Last Post: 11-11-2004, 05:38 PM
  5. 2005 MAZDA3
    By MazdaTree in forum Mazda3 General Discussion
    Last Post: 10-06-2004, 08:08 AM
