Results 1 to 2 of 2
Thread: Wheel Bearing
    Mar 2018
    Peterborough
    Default Wheel Bearing
    When it comes to wheel bearings on a MS3,does anybody know if you can just replace the bearing or does the whole hub assembly need to be replaced?
    Newbie PoSaiDoN's Avatar
    Jun 2009
    Bourget, ON
    Default Re: Wheel Bearing
    The front
    Just the wheel bearing / it requires a press to remove and replace.
    You can bring the entire assembly to a shop and have them do it for you /
    The rear
    Replacement assembly
    Quote Originally Posted by theurgy View Post
    "It's a Turbo thing baby... now shut up and look pretty"...
    MUAHAHAHA
  1. Wheel hub and bearing
    By Joshua in forum Mazda3 General Discussion
    Last Post: 05-30-2012, 11:12 PM
  2. Wheel bearing whine , But wheel bearing's are fine, any ideas?
    By sol_searchin in forum Problems with the Mazda3
    Last Post: 02-11-2011, 07:31 PM
  3. Bad Wheel Bearing!! Help
    By mz3~Power in forum Problems with the Mazda3
    Last Post: 01-15-2011, 02:17 PM
  4. aftermarket vs oem wheel hub assembly (wheel bearing)
    By silvermist99 in forum Engine & Drivetrain
    Last Post: 11-27-2009, 03:44 PM
  5. Wheel bearing
    By MAZDA Kitten in forum Problems with the Mazda3
    Last Post: 09-14-2008, 02:53 AM
