Results 1 to 4 of 4
Thread: Caps missing?
    Jun 2018
    Default Caps missing?
    Hi everyone,
    Recently put changed my Mazda 3, and upon looking under the hood, looks like 2 caps on some line are missing. Could someone tell me what line this is, and if not having the caps is an issue? Thanks!
    Jr Member distr0's Avatar
    Jan 2009
    Default Re: Caps missing?
    Looks like those are the AC High Pressure and Low Pressure Lines. The caps that go on there are to cover up the schrader valves used to fill/discharge the lines. You should probably get some to cover it back up as to not get gunk in there.
  3. The Following User Says Thank You to distr0 For This Useful Post:
    Dai (07-06-2018)
    Orillia
    Yep AC line. Those need to be replaced
  5. The Following User Says Thank You to jeff7670 For This Useful Post:
    Dai (07-06-2018)
  6. #4
    go back to the shop and make them replace the caps
    they were sloppy and didn't do the job right!
    the caps are there to keep stuff from going in, as the others said, but it also helps keep the refrigerant from coming out!
  7. The Following User Says Thank You to TheMAN For This Useful Post:
    Dai (07-06-2018)
  1. I think something is missing from my car
    By Observer in forum New User's Lounge
    Last Post: 10-28-2011, 02:41 PM
  2. Can't believe what we're missing out on in NA...
    By Logikz in forum Mazda3 General Discussion
    Last Post: 05-05-2011, 03:01 AM
  3. Am I missing something?
    By melissa in forum Mazda3 General Discussion
    Last Post: 04-20-2010, 05:50 PM
  4. Missing Friend
    By BETRTHNU in forum General Lounge
    Last Post: 02-23-2009, 06:06 PM
