Results 1 to 3 of 3
Thread: Small coolant leak
    Sr Member thanu31's Avatar
    2003 Honda S2000
    19 Post(s)
    Default Small coolant leak
    Hey guys...its been a long time since I stepped foot in here but need some help with my mazda3
    07 GT with 206000km. Been great but past month or two its been slowly leaking coolant. I usually see a puddle in the passenger side.
    Other symptoms...heat only works if I accelerate.
    After looking everywhere I finally spotted a wet spot near where I think the thermostat is.
    Could this be a case of a bad thermostat? Could a stuck open thermostat cause leaking?
    Thanks in advance
    Past:
    2003 Protege5
    2007 Mazda3 GT
    2002 E46
    ///M
    2010 Mazdaspeed3
    2003 Honda S2000
    Current:
    2005 S2000
    Sr Member Noisy Crow's Avatar
    Default Re: Small coolant leak
    Stuck thermostat, no. Leaking gasket, maybe. You can get dye that will help pinpoint the exact location of the leak.
    As for the lack of heat... probably plugged heater core. You can try having it flushed, easy enough to do.
    not necessarily
    low coolant will cause air pockets in the system, which means lack of ability transfer heat to the radiator or heater core.... higher rpm will reduce the size of the air pockets, making heat transfer more possible
    a slow leak like this could also be a bad water pump... go look to see if it's leaking
  1. Coolant leak from I don't know what is this part.
    By samuel95_54 in forum Engine & Drivetrain
    Last Post: 09-09-2015, 01:06 PM
  2. Coolant leak FML
    By zoomzoom! in forum Engine & Drivetrain
    Last Post: 04-24-2014, 07:04 AM
  3. coolant leak - 2004 mazda 3 GT
    By yuro in forum Problems with the Mazda3
    Last Post: 04-10-2014, 12:04 PM
  4. Coolant leak location
    By boxjohn in forum Engine & Drivetrain
    Last Post: 07-31-2013, 07:30 AM
  5. Coolant leak, confused?
    By tommy36 in forum Problems with the Mazda3
    Last Post: 08-06-2006, 09:44 PM
