Results 1 to 6 of 6
Thread: Strange vibration issue
    Nov 2015
    Default Strange vibration issue
    I'm dealing with a strange vibration. Here are the facts:
    - happens only between 85 - 90 km/h (52-55mph)
    - feel it less while accelerating and more while coasting/letting the gas off
    - feels more on car's body/floor/seat than on steering wheel
    - feel it less when car is cold and outside very cold (> - 10 C), and/or under load (one passenger)
    - excluding wheels balancing problem (happens identically with 2 different sets)
    - excluding engine mounts (both driver and passenger were replaced), inspected RMM and it seems to be good
    Car is 2011, a bit over 100k, 2.0 A/T. Otherwise runs well and it's a really good car.
    Any suggestions/ideas are really appreciated.
    Mar 2017
    Mount Albert
    Default Re: Strange vibration issue
    when is the last time you had an alignment done?
    Nov 2015
    I had an alignment done several months ago (Sep 2017). Everything was in specs.
    Quote Originally Posted by ender2 View Post
    I get wheel / steering wheel/car vibration in the winter...
    Ice and snow in the rims messes up balancing
    Only noticeable at certain speeds
    Goes away when temp warms up or snow ice melts.
    Orillia
    Your CV axles? That is hard to pinpoint. Your ride being an AT seems to me that maybe at a certain,gear,load your engine has a small hesitation
    Newbie LiviuTincu's Avatar
    Nov 2010
    5 Post(s)
    Ball joint maybe, but the alignment guy should have been said something.
    Sent from my Moto G (4) using Tapatalk
  1. Strange electrical issue. Bad negative?
    By kvior in forum Problems with the Mazda3
    Last Post: 05-03-2019, 07:39 AM
  2. HELP! Strange starting issue
    By BTMS110 in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 12-22-2015, 01:06 AM
  3. Rpm, brake pedal and vibration issue! Please help!
    By Pc39445 in forum Problems with the Mazda3
    Last Post: 12-06-2014, 03:02 PM
  4. STRANGE ISSUE: Fog Lights - Non-Functional
    By JackalX3 in forum Electrical
    Last Post: 02-21-2012, 09:23 PM
