Results 1 to 10 of 10
Thread: Drive belt needs to go?
    Jr Member ptgrad2012's Avatar
    Aug 2012
    Default Drive belt needs to go?
    Hi all,
    Brought car to dealer today for oil change, comments came up re:
    -drive belt needs to be changed, according to this pic, would you say so too? (belt and water pump pulley was changed at 111,300km , currently car at 161000 km, 6.5 yrs old)
    -water pump starts to leak; I am guessing it's those two green dots on the bottom left of pic. (quoted for $690 + tax to change belt, water pump, and pulley)
    -lastly, mechanic said he could smell a burning smell at the alternator, which he said it would usually die in 2 months or so. I tried to smell it, but I can't really smell it. (Quoted for $1040 + tax for alternator)
    Just wondering if they sound right?
    Orillia
    Default Re: Drive belt needs to go?
    My gen 1 belts at 260k are just fine....yours look ok however they do look overly tight. Those two green dots on your AC line are not coolant, so don't worry about that. If your water pump needs to be changed they must have done a poor job replacing the pulley, although they wouldn't have removed the pump to change the pulley. A smell from the alternator.....sorry ptgrad2012 I think the dealer is trying to get some money from you. Water pump issues from mz3 aren't common.
    Aug 2012
    Quote Originally Posted by jeff7670 View Post
    yeah, i had the same feeling with the smell comment.. everything is okay so far, I did change the battery recently, had it stalling next day, but remedied by letting it sit idle 20 mins to relearn; it runs fine now.
    I guess I will just keep an eye out to see if there's any leak on the parking lot, and keep an eye out if there's any electrical issues.
    Thanks!
    Quote Originally Posted by ptgrad2012 View Post
    Thanks!
    From the sounds of it your going to the wrong place to get repairs done. Smell from the alternator? LMAO. Just have someone test it properly for proper output voltage.
    Those prices quoted are also ludicrous, $1000 for an alternator replacement?
    As Jeff said above those dots are nothing most likely from the factory as I have them also, so not leakage, and from what I can see your engine is pretty clean with no signs of leaks.
    Newbie LiviuTincu's Avatar
    Nov 2010
    5 Post(s)
    Hi all,
    Check the marks on the pulley, three lines, middle should be lining up with the other line. If is off too much, you have to replace the drive belt. You can check the voltage if you have a obd 2, should run around 14.2v, if is around 13v belt is lose, stretched, replace it. This is my experience with the belt which I have replaced 5 months ago.
    Sent from my Moto G (4) using Tapatalk
    Nov 2010
    5 Post(s)
    When water pump leaks, the coolant reservoir is low , you will see that right away , + it smell when hot.
    I agree with Liv and Jeff and Flag.
    Get a second opinion ...
    i replaced my Serpentine Belt at 200K and swapped in lightweight pulleys at the same time.
    with a non dealership mech ...an 1hr labor.
    Aug 2012
    Just an update:
    went to Jimmy's today, he looked at the belt- normal wear, tested the battery-alternator is fine. He did find some stain at the water pump, told me to keep an eye on it in the summer as high pressure from the coolant could make it leak.
    129 Post(s)
    where did you get the pulleys from?
    Costco = good cheap solution
    It's like a buck a nut
    http://www.shaneracing.com/Mazda3_Pe...r_Pulleys.html
    Their website has not been updated in years ....
    The Pulleys fit ..im running a full set....They fit MZR 2.0 and 2.3 up to 2013
    (not sure about skyactiv engine and later years....)
  1. A/C Belt & Acc Belt & Tensioner need to be changed??? :(
    By sky_active in forum Engine & Drivetrain
    Last Post: 06-06-2013, 10:48 AM
  2. Alternator Drive Belt - Look Normal?
    By thespecialist in forum Problems with the Mazda3
    Last Post: 11-09-2012, 08:48 PM
  3. Is it okay to drive with no AC belt?
    By cb474 in forum Problems with the Mazda3
    Last Post: 05-22-2012, 07:05 AM
  4. What belt is this and does it look ok?
    By Olestra in forum Engine & Drivetrain
    Last Post: 04-22-2012, 07:26 PM
  5. Drive belt tensioner?
    By Flagrum_3 in forum Engine & Drivetrain
    Last Post: 01-12-2007, 11:41 PM
