Results 1 to 5 of 5
Thread: Mazda 3 2015 Driver side window would not go up
    Sep 2019
    Default Mazda 3 2015 Driver side window would not go up
    Hi guys
    For the last 2 weeks, my driver side window would go down easily but it would not always come back up. I had to try many times and it would come up all at once or come up couple of inches at a time. After few trials, it closed. 3 days ago, it came down but did not go back up at all. When I pull the switch to shut, it clicks/tries to move it and it moves 1-2 mm up but falls down again. Tried multiple times, but does not go up. Now It is completely stuck! Looking for help. Thanks.
    Default Re: Mazda 3 2015 Driver side window would not go up
    Quote Originally Posted by ManojG View Post
    Hi guys
    Sounds like the switch is done, or possibly the motor. But I would guess switch first.
    Sep 2019
    Thanks but just to double check- the switch clicks and makes the right sound when I try to use it. Even with that, do you think it could be switch?
    Well same happened to me a few years back. Window would go down but take several tries with the switch to bring it up. Got worse over time so I replaced it. Issue solved.
    If the window is going down at every try the motor is still good.
    Sep 2019
    Ok. I will try the switch first and see how it goes.
  1. Driver side window does not go up
    By trademark83 in forum Problems with the Mazda3
    Last Post: 01-19-2016, 10:49 PM
  2. 2014 Mazda 3 cracking sound from driver side window.
    By 7thgen in forum Problems with the Mazda3
    Last Post: 07-24-2014, 09:28 AM
  3. Driver side window
    By omalak in forum Problems with the Mazda3
    Last Post: 11-21-2008, 11:59 PM
  4. Driver's side window
    By BLKOUT in forum Problems with the Mazda3
    Last Post: 03-18-2008, 03:50 AM
  5. Driver side Window
    By Ex-Rolla in forum Problems with the Mazda3
    Last Post: 07-26-2005, 04:30 PM
